Hello guys!
I want to make an FPGA kit which has cyclone V CEFA9F27I7N chip and a desktop Ram socket. I didn't design any FPGA board before but i have experience in pcb designing. So if any one guide me what circuits should i need to make these both main components works. thanks
Always search for PCB Design User Guides for both: FPGA chip and desktop Ram socket.
E.g. for any Xilinx's FPGAs there is always a PCB Design User Guide document.
You could also download the schematic of any Xilinx made board, with the bom for that board. All the Xilinx branded development kits have schematics, so you'll see what the Xilinx engineers required on their boards to make the FPGA work. It will also give you a good idea how the point of load power supplies should be done.
Haven't looked at Altera in years so don't know if they still have schematics of their boards for download too.
Unfortunately Xilinx's development kits PCBs are sometimes incompatible with actual and official Xilinx's PCB Design User Guide.
It is important to read the last release of it.
I'm not familiar with Altera's products so I can't help much.
I have been looking to make a board with the 5CEFA9F23C7N (only 484 BGA) my goal was to have it on a 4 layer PCB since I only need a few IO and JTAG + QSPI Flash + 1.1V reg
With the A9 are if you use all 301K the LE in the chip for mostly pipeline on fmax and have action on every clk you will need heat-sink + fan and a high current 1.1 V reg
I actually ended up buying a few BeMicro CV-A9 ($150) now obsolete, but you have all the BOM, schematic, PCB lay online.
sure it would have been better with the speed-grade -7, also I had to add heat-sink and tweak the 1.1V to provide a bit more current
