[SOLVED] Forward type XFMR from PE
CataM
Madrid, Spain
Hi everyone,
I need a Forward type XFMR rated for 30V in the primary, 100kHz, Npri/Nsec=6, Isec>5A.
I found the PA3856.001NL which almost suits.. the problem is the frequency.
How can I know if the XFMR from Pulse Engineering rated at 200kHz will saturate at 100 kHz if I do not know what ferrite they are using ?
Can anyone tell if it is safe if I use this rule of thumb to estimate the saturation flux density: Bmaxworst case conditions given by manufacturer design/Bsat=65% ?
Worst case conditions given by manufacturer: Vin=57V, 200kHz, D=50%.
Any comment is appreciated.
Where do you see D=50%? Duty cycle for rated output voltage is about 0.35 with 57 V input. You get the designed flux at 100 kHz with half the output voltage.
Reactions: CataM
    CataM
O.K. You are correct. I was mistaken.
I see that they are providing the K1 factor but they use it for the Flyback. Are they using the same core material for both Flyback and Forward ?
I'm quite sure both transformers differ only by air gap. If the flux is below saturation, half frequency may allow up to 50 % flux increase with constant loss, but not 100 %.
Reactions: CataM
    CataM
Yeah they are... the core loss is calculated with the same parameters for both topologies.
By the way, Bmaxmanufacturer worst case conditions/Bsat=(2773.05 gauss /2)/2700 gauss~50% .. close to my initial assumption of post #1.
In a fwd converter at 100Khz, the peak B of the AC flux swing should be 100mT or less, so 0-200mT and back to near zero is a an AC flux swing of 100mT, pushing harder assumes a very good core material ...
I think that is relative to the specific application.
The referenced XFMR in worst case conditions given by the manufacturer has 277.3 mT swing, respectively 277.3/2=138.65 mT peak, which gives about 245mW core loss.
That core loss seems reasonable, taking into account that it is a XFMR rated at 50W.
Ah well for 50W, you may well get away with it - esp if ambient < 30 degC ...
Also contact pulse. I reached out to them once and was pleased with a good honest response from a real engineer. Now they’re high on my inductor supplier list (next to coilcraft who has the best website).
Reactions: CataM
    CataM
