promach
What do you guys think about the multiplier code below ?
sgnmpy_32x32.v
umpy_32x32.v
bimpy.v
sgnmpy_32x32.v
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 //////////////////////////////////////////////////////////////////////////////// // // Filename: sgnmpy_32x32.v // // Project: A multiply core generator // // Purpose: Turns a signed multiply into an unsigned multiply, at the cost // of two clocks and a negation. // // // Creator: Dan Gisselquist, Ph.D. // Gisselquist Tecnology, LLC // //////////////////////////////////////////////////////////////////////////////// // // Copyright (C) 2015,2017, Gisselquist Technology, LLC // // This program is free software (firmware): you can redistribute it and/or // modify it under the terms of the GNU General Public License as published // by the Free Software Foundation, either version 3 of the License, or (at // your option) any later version. // // This program is distributed in the hope that it will be useful, but WITHOUT // ANY WARRANTY; without even the implied warranty of MERCHANTIBILITY or // FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License // for more details. // // You should have received a copy of the GNU General Public License along // with this program. If not, see <http://www.gnu.org/licenses/> for a // copy. // // License: GPL, v3, as defined and found on [url]www.gnu.org[/url], // [url]https://www.gnu.org/licenses/gpl.html[/url] // // //////////////////////////////////////////////////////////////////////////////// module sgnmpy_32x32(i_clk, i_reset, i_ce, i_a, i_b, i_aux, o_p, o_aux); parameter NA=32, NB=32, DLY=6; input i_clk, i_reset, i_ce; input signed [(NA-1):0] i_a; input signed [(NB-1):0] i_b; input i_aux; output reg signed [(NA+NB-1):0] o_p; output reg o_aux; localparam NS = (NA < NB) ? NA : NB; localparam NL = (NA < NB) ? NB : NA; wire [(NS-1):0] i_s; // Smaller input wire [(NL-1):0] i_l; // larger input // // Adjust our inputs so that i_s has the fewest bits, and i_b the most generate if (NA < NB) begin : BITADJ assign i_s = i_a; assign i_l = i_b; end else begin assign i_s = i_b; assign i_l = i_a; end endgenerate reg [(NS-1):0] u_s; reg [(NL-1):0] u_l; reg [(DLY-1):0] u_sgn; reg u_aux; initial u_aux = 1'b0; always @(posedge i_clk) if(i_reset) u_aux <= 1'b0; else if (i_ce) u_aux <= i_aux; initial u_s = 0; initial u_l = 0; always @(posedge i_clk) if(i_reset) begin u_s <= 0; u_l <= 0; end else if (i_ce) begin u_s <= (i_s[NS-1])?(-i_s):i_s; u_l <= (i_l[NL-1])?(-i_l):i_l; end initial u_sgn = 0; always @(posedge i_clk) if(i_reset) u_sgn <= 0; else if (i_ce) u_sgn <= { u_sgn[(DLY-2):0], ((i_s[NS-1])^(i_l[NL-1])) }; wire [(NA+NB-1):0] u_r; wire w_aux; umpy_32x32 umpy(i_clk, i_reset, i_ce, u_s, u_l, u_aux, u_r, w_aux); initial o_p = 0; always @(posedge i_clk) if(i_reset) o_p <= 0; else if (i_ce) o_p <= (u_sgn[DLY-1])?(-u_r):u_r; initial o_aux = 1'b0; always @(posedge i_clk) if(i_reset) o_aux <= 1'b0; else if (i_ce) o_aux <= w_aux; endmodule
umpy_32x32.v
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 //////////////////////////////////////////////////////////////////////////////// // // Filename: umpy_32x32.v // // Project: A multiply core generator // // Purpose: This verilog file multiplies two unsigned numbers together, // without using any hardware acceleration. This file is // computer generated, so please (for your sake) don't make any edits // to this file lest you regenerate it and your edits be lost. // // // Creator: Dan Gisselquist, Ph.D. // Gisselquist Tecnology, LLC // //////////////////////////////////////////////////////////////////////////////// // // Copyright (C) 2015,2017, Gisselquist Technology, LLC // // This program is free software (firmware): you can redistribute it and/or // modify it under the terms of the GNU General Public License as published // by the Free Software Foundation, either version 3 of the License, or (at // your option) any later version. // // This program is distributed in the hope that it will be useful, but WITHOUT // ANY WARRANTY; without even the implied warranty of MERCHANTIBILITY or // FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License // for more details. // // You should have received a copy of the GNU General Public License along // with this program. If not, see <http://www.gnu.org/licenses/> for a // copy. // // License: GPL, v3, as defined and found on [url]www.gnu.org[/url], // [url]https://www.gnu.org/licenses/gpl.html[/url] // // //////////////////////////////////////////////////////////////////////////////// module umpy_32x32(i_clk, i_reset, i_ce, i_a, i_b, i_aux, o_p, o_aux); parameter NA=32, NB=32; input i_clk, i_reset, i_ce; input signed [(NA-1):0] i_a; input signed [(NB-1):0] i_b; input i_aux; output reg signed [(NA+NB-1):0] o_p; output reg o_aux; localparam NS = (NA < NB) ? NA : NB; localparam NL = (NA < NB) ? NB : NA; wire [(NS-1):0] i_s; // Smaller input wire [(NL-1):0] i_l; // larger input // // Adjust our inputs so that i_s has the fewest bits, and i_b the most generate if (NA < NB) begin : BITADJ assign i_s = i_a; assign i_l = i_b; end else begin assign i_s = i_b; assign i_l = i_a; end endgenerate // Clock zero: build our Tableau only. // There will be one row for every pair of bits in i_a, and each // row will contain (AW+3) bits, to allow // for signed arithmetic manipulation. // reg A_0; wire [33:0] S_0_00; bimpy #(NB) initialmpy_0_0(i_clk, i_reset, i_ce, i_s[1:0], i_l, S_0_00); wire [33:0] S_0_01; bimpy #(NB) initialmpy_1_0(i_clk, i_reset, i_ce, i_s[3:2], i_l, S_0_01); wire [33:0] S_0_02; bimpy #(NB) initialmpy_2_0(i_clk, i_reset, i_ce, i_s[5:4], i_l, S_0_02); wire [33:0] S_0_03; bimpy #(NB) initialmpy_3_0(i_clk, i_reset, i_ce, i_s[7:6], i_l, S_0_03); wire [33:0] S_0_04; bimpy #(NB) initialmpy_4_0(i_clk, i_reset, i_ce, i_s[9:8], i_l, S_0_04); wire [33:0] S_0_05; bimpy #(NB) initialmpy_5_0(i_clk, i_reset, i_ce, i_s[11:10], i_l, S_0_05); wire [33:0] S_0_06; bimpy #(NB) initialmpy_6_0(i_clk, i_reset, i_ce, i_s[13:12], i_l, S_0_06); wire [33:0] S_0_07; bimpy #(NB) initialmpy_7_0(i_clk, i_reset, i_ce, i_s[15:14], i_l, S_0_07); wire [33:0] S_0_08; bimpy #(NB) initialmpy_8_0(i_clk, i_reset, i_ce, i_s[17:16], i_l, S_0_08); wire [33:0] S_0_09; bimpy #(NB) initialmpy_9_0(i_clk, i_reset, i_ce, i_s[19:18], i_l, S_0_09); wire [33:0] S_0_10; bimpy #(NB) initialmpy_10_0(i_clk, i_reset, i_ce, i_s[21:20], i_l, S_0_10); wire [33:0] S_0_11; bimpy #(NB) initialmpy_11_0(i_clk, i_reset, i_ce, i_s[23:22], i_l, S_0_11); wire [33:0] S_0_12; bimpy #(NB) initialmpy_12_0(i_clk, i_reset, i_ce, i_s[25:24], i_l, S_0_12); wire [33:0] S_0_13; bimpy #(NB) initialmpy_13_0(i_clk, i_reset, i_ce, i_s[27:26], i_l, S_0_13); wire [33:0] S_0_14; bimpy #(NB) initialmpy_14_0(i_clk, i_reset, i_ce, i_s[29:28], i_l, S_0_14); wire [33:0] S_0_15; bimpy #(NB) initialmpy_15_0(i_clk, i_reset, i_ce, i_s[31:30], i_l, S_0_15); initial A_0 = 0; always @(posedge i_clk) if(i_reset) A_0 <= 1'b0; else if (i_ce) A_0 <= i_aux; // // Round #1, clock = 1, nz = 2, nbits = 34, nrows_in = 16 // reg [(37-1):0] S_1_00; // maxbits = 64 reg [(37-1):0] S_1_01; // maxbits = 64 reg [(37-1):0] S_1_02; // maxbits = 64 reg [(37-1):0] S_1_03; // maxbits = 64 reg [(37-1):0] S_1_04; // maxbits = 64 reg [(37-1):0] S_1_05; // maxbits = 64 reg [(37-1):0] S_1_06; // maxbits = 64 reg [(37-1):0] S_1_07; // maxbits = 64 reg A_1; initial S_1_00 = 0; initial S_1_01 = 0; initial S_1_02 = 0; initial S_1_03 = 0; initial S_1_04 = 0; initial S_1_05 = 0; initial S_1_06 = 0; initial S_1_07 = 0; always @(posedge i_clk) if(i_reset) begin S_1_00 <= 0; S_1_01 <= 0; S_1_02 <= 0; S_1_03 <= 0; S_1_04 <= 0; S_1_05 <= 0; S_1_06 <= 0; S_1_07 <= 0; end else if (i_ce) begin S_1_00 <= { 2'b0, S_0_00 } + { S_0_01, 2'b0 }; S_1_01 <= { 2'b0, S_0_02 } + { S_0_03, 2'b0 }; S_1_02 <= { 2'b0, S_0_04 } + { S_0_05, 2'b0 }; S_1_03 <= { 2'b0, S_0_06 } + { S_0_07, 2'b0 }; S_1_04 <= { 2'b0, S_0_08 } + { S_0_09, 2'b0 }; S_1_05 <= { 2'b0, S_0_10 } + { S_0_11, 2'b0 }; S_1_06 <= { 2'b0, S_0_12 } + { S_0_13, 2'b0 }; S_1_07 <= { 2'b0, S_0_14 } + { S_0_15, 2'b0 }; end initial A_1 = 0; always @(posedge i_clk) if(i_reset) A_1 <= 1'b0; else if (i_ce) A_1 <= A_0; // // Round #2, clock = 2, nz = 4, nbits = 37, nrows_in = 8 // reg [(42-1):0] S_2_00; // maxbits = 64 reg [(42-1):0] S_2_01; // maxbits = 64 reg [(42-1):0] S_2_02; // maxbits = 64 reg [(42-1):0] S_2_03; // maxbits = 64 reg A_2; initial S_2_00 = 0; initial S_2_01 = 0; initial S_2_02 = 0; initial S_2_03 = 0; always @(posedge i_clk) if(i_reset) begin S_2_00 <= 0; S_2_01 <= 0; S_2_02 <= 0; S_2_03 <= 0; end else if (i_ce) begin S_2_00 <= { 4'b0, S_1_00 } + { S_1_01, 4'b0 }; S_2_01 <= { 4'b0, S_1_02 } + { S_1_03, 4'b0 }; S_2_02 <= { 4'b0, S_1_04 } + { S_1_05, 4'b0 }; S_2_03 <= { 4'b0, S_1_06 } + { S_1_07, 4'b0 }; end initial A_2 = 0; always @(posedge i_clk) if(i_reset) A_2 <= 1'b0; else if (i_ce) A_2 <= A_1; // // Round #3, clock = 3, nz = 8, nbits = 42, nrows_in = 4 // reg [(51-1):0] S_3_00; // maxbits = 64 reg [(51-1):0] S_3_01; // maxbits = 64 reg A_3; initial S_3_00 = 0; initial S_3_01 = 0; always @(posedge i_clk) if(i_reset) begin S_3_00 <= 0; S_3_01 <= 0; end else if (i_ce) begin S_3_00 <= { 8'b0, S_2_00 } + { S_2_01, 8'b0 }; S_3_01 <= { 8'b0, S_2_02 } + { S_2_03, 8'b0 }; end initial A_3 = 0; always @(posedge i_clk) if(i_reset) A_3 <= 1'b0; else if (i_ce) A_3 <= A_2; // // Round #4, clock = 4, nz = 16, nbits = 51, nrows_in = 2 // reg [(64-1):0] S_4_00; // maxbits = 64 reg A_4; initial S_4_00 = 0; always @(posedge i_clk) if(i_reset) begin S_4_00 <= 0; end else if (i_ce) begin S_4_00 <= { 13'b0, S_3_00 } + { S_3_01// Adding to unused: 68, 64 [47:0], 16'b0 }; // unused = 3, ustr = S_3_01[50:48] end initial A_4 = 0; always @(posedge i_clk) if(i_reset) A_4 <= 1'b0; else if (i_ce) A_4 <= A_3; assign o_p = S_4_00[(NA+NB-1):0]; assign o_aux = A_4; // Make verilator happy // verilator lint_off UNUSED wire [3-1:0] unused; assign unused = { S_3_01[50:48] }; // verilator lint_on UNUSED `ifdef FORMAL reg f_past_valid; initial f_past_valid = 0; always @(posedge i_clk) f_past_valid <= 1'b1; wire [4+1:0] f_auxpipe; assign f_auxpipe = { A_4,A_3,A_2,A_1,A_0, i_aux }; initial assume(!i_aux); always @(posedge i_clk) if ((i_reset)||((f_past_valid)&&($past(i_reset)))) assume(!i_aux); initial assert(f_auxpipe == 0); always @(posedge i_clk) if ((f_past_valid)&&($past(i_reset))) assert(f_auxpipe == 0); always @(posedge i_clk) if ((f_past_valid)&&(!$past(i_reset))&&($past(i_ce))) assert(f_auxpipe[4+1:1] == $past(f_auxpipe[4:0])); always @(posedge i_clk) if ((f_past_valid)&&(!$past(i_reset))&&(!$past(i_ce))) assert(f_auxpipe[4+1:1] == $past(f_auxpipe[4+1:1])); localparam F_DELAY = 4; reg [NA+NB-1:0] f_result; integer ik; initial f_result = 0; always @(posedge i_clk) if(i_reset) f_result = 0; else if (i_ce) begin f_result = 0; for(ik=0; ik<NS; ik=ik+1) if(i_a[ik]) f_result = f_result + { {(NL-ik-1){1'b0}}, i_b, { (ik){1'b0} } }; end reg [F_DELAY*(NA+NB)-1:0] f_result_pipe; initial f_result_pipe = 0; always @(posedge i_clk) if(i_reset) f_result_pipe <= 0; else if (i_ce) f_result_pipe <= { f_result, f_result_pipe[((F_DELAY)*(NA+NB)-1):(NA+NB)] }; always @(posedge i_clk) assert(o_p == f_result_pipe[(NA+NB-1):0]); always @(posedge i_clk) assume((i_ce) ||((f_past_valid)&&($past(i_ce))) // ||(($past(f_past_valid))&&($past(i_ce,2))) ); `endif endmodule
bimpy.v
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 //////////////////////////////////////////////////////////////////////////////// // // Filename: bimpy // // Project: A multiply core generator // // Purpose: An unsigned 2-bit multiply based upon the fact that LUT's allow // 6-bits of input, but a 2x2 bit multiply will never carry more // than one bit. While this multiply is hardware independent, it is // really motivated by trying to optimize for a specific piece of // hardware (Xilinx-7 series ...) that has 4-input LUT's with carry // chains. // // Creator: Dan Gisselquist, Ph.D. // Gisselquist Tecnology, LLC // //////////////////////////////////////////////////////////////////////////////// // // Copyright (C) 2015,2017, Gisselquist Technology, LLC // // This program is free software (firmware): you can redistribute it and/or // modify it under the terms of the GNU General Public License as published // by the Free Software Foundation, either version 3 of the License, or (at // your option) any later version. // // This program is distributed in the hope that it will be useful, but WITHOUT // ANY WARRANTY; without even the implied warranty of MERCHANTIBILITY or // FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License // for more details. // // You should have received a copy of the GNU General Public License along // with this program. If not, see <http://www.gnu.org/licenses/> for a // copy. // // License: GPL, v3, as defined and found on [url]www.gnu.org[/url], // [url]https://www.gnu.org/licenses/gpl.html[/url] // // //////////////////////////////////////////////////////////////////////////////// module bimpy(i_clk, i_reset, i_ce, i_a, i_b, o_r); parameter BW=18, LUTB=2; input i_clk, i_reset, i_ce; input [(LUTB-1):0] i_a; input [(BW-1):0] i_b; output reg [(BW+LUTB-1):0] o_r; wire [(BW+LUTB-2):0] w_r; wire [(BW+LUTB-3):1] c; assign w_r = { ((i_a[1])?i_b:{(BW){1'b0}}), 1'b0 } ^ { 1'b0, ((i_a[0])?i_b:{(BW){1'b0}}) }; assign c = { ((i_a[1])?i_b[(BW-2):0]:{(BW-1){1'b0}}) } & ((i_a[0])?i_b[(BW-1):1]:{(BW-1){1'b0}}); initial o_r = 0; always @(posedge i_clk) if (i_reset) o_r <= 0; else if (i_ce) o_r <= w_r + { c, 2'b0 }; endmodule
