Formal verification of mutiplier verilog code
promach
What do you guys think about the multiplier code below ?
sgnmpy_32x32.v
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
// Filename:    sgnmpy_32x32.v
// Project: A multiply core generator
// Purpose: Turns a signed multiply into an unsigned multiply, at the cost
//  of two clocks and a negation.
// Creator: Dan Gisselquist, Ph.D.
//      Gisselquist Tecnology, LLC
// Copyright (C) 2015,2017, Gisselquist Technology, LLC
// This program is free software (firmware): you can redistribute it and/or
// modify it under the terms of  the GNU General Public License as published
// by the Free Software Foundation, either version 3 of the License, or (at
// your option) any later version.
// This program is distributed in the hope that it will be useful, but WITHOUT
// ANY WARRANTY; without even the implied warranty of MERCHANTIBILITY or
// FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
// for more details.
// You should have received a copy of the GNU General Public License along
// with this program.  If not, see <http://www.gnu.org/licenses/> for a
// copy.
// License: GPL, v3, as defined and found on [url]www.gnu.org[/url],
//      [url]https://www.gnu.org/licenses/gpl.html[/url]
module sgnmpy_32x32(i_clk, i_reset, i_ce, i_a, i_b, i_aux, o_p, o_aux);
    parameter   NA=32, NB=32, DLY=6;
    input                   i_clk, i_reset, i_ce;
    input       signed  [(NA-1):0]  i_a;
    input       signed  [(NB-1):0]  i_b;
    input                   i_aux;
    output  reg signed  [(NA+NB-1):0]   o_p;
    output  reg             o_aux;
    localparam NS = (NA < NB) ? NA : NB;
    localparam NL = (NA < NB) ? NB : NA;
    wire    [(NS-1):0]  i_s;    // Smaller input
    wire    [(NL-1):0]  i_l;    // larger input
    // Adjust our inputs so that i_s has the fewest bits, and i_b the most
    generate if (NA < NB)
    begin : BITADJ
        assign  i_s = i_a;
        assign  i_l = i_b;
    end else begin
        assign  i_s = i_b;
        assign  i_l = i_a;
    end endgenerate
    reg     [(NS-1):0]  u_s;
    reg     [(NL-1):0]  u_l;
    reg     [(DLY-1):0] u_sgn;
    reg             u_aux;
    initial u_aux = 1'b0;
    always @(posedge i_clk)
    if(i_reset)
            u_aux <= 1'b0;
        else if (i_ce)
            u_aux <= i_aux;
    initial u_s = 0;
    initial u_l = 0;
    if(i_reset)
    begin
        u_s <= 0;
        u_l <= 0;
    end else if (i_ce)
    begin
        u_s <= (i_s[NS-1])?(-i_s):i_s;
        u_l <= (i_l[NL-1])?(-i_l):i_l;
    end
    initial u_sgn = 0;
    if(i_reset)
        u_sgn <= 0;
    else if (i_ce)
        u_sgn <= { u_sgn[(DLY-2):0], ((i_s[NS-1])^(i_l[NL-1])) };
    wire    [(NA+NB-1):0]   u_r;
    wire            w_aux;
    umpy_32x32  umpy(i_clk, i_reset, i_ce, u_s, u_l, u_aux, u_r, w_aux);
    initial o_p = 0;
    if(i_reset)
        o_p <= 0;
    else if (i_ce)
        o_p <= (u_sgn[DLY-1])?(-u_r):u_r;
    initial o_aux = 1'b0;
    if(i_reset)
        o_aux <= 1'b0;
    else if (i_ce)
        o_aux <= w_aux;
endmodule
umpy_32x32.v
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
// Filename:    umpy_32x32.v
// Purpose: This verilog file multiplies two unsigned numbers together,
//      without using any hardware acceleration.  This file is
//  computer generated, so please (for your sake) don't make any edits
//  to this file lest you regenerate it and your edits be lost.
// copy.
module umpy_32x32(i_clk, i_reset, i_ce, i_a, i_b, i_aux, o_p, o_aux);
    parameter   NA=32, NB=32;
    input                   i_aux;
    output  reg             o_aux;
    begin : BITADJ
        assign  i_s = i_a;
        assign  i_l = i_b;
    end else begin
        assign  i_s = i_b;
        assign  i_l = i_a;
    end endgenerate
    // Clock zero: build our Tableau only.
    // There will be one row for every pair of bits in i_a, and each
    // row will contain (AW+3) bits, to allow
    // for signed arithmetic manipulation.
    reg A_0;
    wire    [33:0]  S_0_00;
    bimpy #(NB) initialmpy_0_0(i_clk, i_reset, i_ce, i_s[1:0], i_l, S_0_00);
    wire    [33:0]  S_0_01;
    bimpy #(NB) initialmpy_1_0(i_clk, i_reset, i_ce, i_s[3:2], i_l, S_0_01);
    wire    [33:0]  S_0_02;
    bimpy #(NB) initialmpy_2_0(i_clk, i_reset, i_ce, i_s[5:4], i_l, S_0_02);
    wire    [33:0]  S_0_03;
    bimpy #(NB) initialmpy_3_0(i_clk, i_reset, i_ce, i_s[7:6], i_l, S_0_03);
    wire    [33:0]  S_0_04;
    bimpy #(NB) initialmpy_4_0(i_clk, i_reset, i_ce, i_s[9:8], i_l, S_0_04);
    wire    [33:0]  S_0_05;
    bimpy #(NB) initialmpy_5_0(i_clk, i_reset, i_ce, i_s[11:10], i_l, S_0_05);
    wire    [33:0]  S_0_06;
    bimpy #(NB) initialmpy_6_0(i_clk, i_reset, i_ce, i_s[13:12], i_l, S_0_06);
    wire    [33:0]  S_0_07;
    bimpy #(NB) initialmpy_7_0(i_clk, i_reset, i_ce, i_s[15:14], i_l, S_0_07);
    wire    [33:0]  S_0_08;
    bimpy #(NB) initialmpy_8_0(i_clk, i_reset, i_ce, i_s[17:16], i_l, S_0_08);
    wire    [33:0]  S_0_09;
    bimpy #(NB) initialmpy_9_0(i_clk, i_reset, i_ce, i_s[19:18], i_l, S_0_09);
    wire    [33:0]  S_0_10;
    bimpy #(NB) initialmpy_10_0(i_clk, i_reset, i_ce, i_s[21:20], i_l, S_0_10);
    wire    [33:0]  S_0_11;
    bimpy #(NB) initialmpy_11_0(i_clk, i_reset, i_ce, i_s[23:22], i_l, S_0_11);
    wire    [33:0]  S_0_12;
    bimpy #(NB) initialmpy_12_0(i_clk, i_reset, i_ce, i_s[25:24], i_l, S_0_12);
    wire    [33:0]  S_0_13;
    bimpy #(NB) initialmpy_13_0(i_clk, i_reset, i_ce, i_s[27:26], i_l, S_0_13);
    wire    [33:0]  S_0_14;
    bimpy #(NB) initialmpy_14_0(i_clk, i_reset, i_ce, i_s[29:28], i_l, S_0_14);
    wire    [33:0]  S_0_15;
    bimpy #(NB) initialmpy_15_0(i_clk, i_reset, i_ce, i_s[31:30], i_l, S_0_15);
    initial A_0 = 0;
    if(i_reset)
        A_0 <= 1'b0;
    else if (i_ce)
        A_0 <= i_aux;
    // Round #1, clock = 1, nz = 2, nbits = 34, nrows_in = 16
    reg [(37-1):0]  S_1_00; // maxbits = 64
    reg [(37-1):0]  S_1_01; // maxbits = 64
    reg [(37-1):0]  S_1_02; // maxbits = 64
    reg [(37-1):0]  S_1_03; // maxbits = 64
    reg [(37-1):0]  S_1_04; // maxbits = 64
    reg [(37-1):0]  S_1_05; // maxbits = 64
    reg [(37-1):0]  S_1_06; // maxbits = 64
    reg [(37-1):0]  S_1_07; // maxbits = 64
    reg A_1;
    initial S_1_00 = 0;
    initial S_1_01 = 0;
    initial S_1_02 = 0;
    initial S_1_03 = 0;
    initial S_1_04 = 0;
    initial S_1_05 = 0;
    initial S_1_06 = 0;
    initial S_1_07 = 0;
    if(i_reset)
    begin
        S_1_00 <= 0;
        S_1_01 <= 0;
        S_1_02 <= 0;
        S_1_03 <= 0;
        S_1_04 <= 0;
        S_1_05 <= 0;
        S_1_06 <= 0;
        S_1_07 <= 0;
    end else if (i_ce)
    begin
        S_1_00 <= { 2'b0, S_0_00 } + { S_0_01, 2'b0 };
        S_1_01 <= { 2'b0, S_0_02 } + { S_0_03, 2'b0 };
        S_1_02 <= { 2'b0, S_0_04 } + { S_0_05, 2'b0 };
        S_1_03 <= { 2'b0, S_0_06 } + { S_0_07, 2'b0 };
        S_1_04 <= { 2'b0, S_0_08 } + { S_0_09, 2'b0 };
        S_1_05 <= { 2'b0, S_0_10 } + { S_0_11, 2'b0 };
        S_1_06 <= { 2'b0, S_0_12 } + { S_0_13, 2'b0 };
        S_1_07 <= { 2'b0, S_0_14 } + { S_0_15, 2'b0 };
    end
    initial A_1 = 0;
    if(i_reset)
        A_1 <= 1'b0;
    else if (i_ce)
        A_1 <= A_0;
    // Round #2, clock = 2, nz = 4, nbits = 37, nrows_in = 8
    reg [(42-1):0]  S_2_00; // maxbits = 64
    reg [(42-1):0]  S_2_01; // maxbits = 64
    reg [(42-1):0]  S_2_02; // maxbits = 64
    reg [(42-1):0]  S_2_03; // maxbits = 64
    reg A_2;
    initial S_2_00 = 0;
    initial S_2_01 = 0;
    initial S_2_02 = 0;
    initial S_2_03 = 0;
    if(i_reset)
    begin
        S_2_00 <= 0;
        S_2_01 <= 0;
        S_2_02 <= 0;
        S_2_03 <= 0;
    end else if (i_ce)
    begin
        S_2_00 <= { 4'b0, S_1_00 } + { S_1_01, 4'b0 };
        S_2_01 <= { 4'b0, S_1_02 } + { S_1_03, 4'b0 };
        S_2_02 <= { 4'b0, S_1_04 } + { S_1_05, 4'b0 };
        S_2_03 <= { 4'b0, S_1_06 } + { S_1_07, 4'b0 };
    end
    initial A_2 = 0;
    if(i_reset)
        A_2 <= 1'b0;
    else if (i_ce)
        A_2 <= A_1;
    // Round #3, clock = 3, nz = 8, nbits = 42, nrows_in = 4
    reg [(51-1):0]  S_3_00; // maxbits = 64
    reg [(51-1):0]  S_3_01; // maxbits = 64
    reg A_3;
    initial S_3_00 = 0;
    initial S_3_01 = 0;
    if(i_reset)
    begin
        S_3_00 <= 0;
        S_3_01 <= 0;
    end else if (i_ce)
    begin
        S_3_00 <= { 8'b0, S_2_00 } + { S_2_01, 8'b0 };
        S_3_01 <= { 8'b0, S_2_02 } + { S_2_03, 8'b0 };
    end
    initial A_3 = 0;
    if(i_reset)
        A_3 <= 1'b0;
    else if (i_ce)
        A_3 <= A_2;
    // Round #4, clock = 4, nz = 16, nbits = 51, nrows_in = 2
    reg [(64-1):0]  S_4_00; // maxbits = 64
    reg A_4;
    initial S_4_00 = 0;
    if(i_reset)
    begin
        S_4_00 <= 0;
    end else if (i_ce)
    begin
        S_4_00 <= { 13'b0, S_3_00 } + { S_3_01// Adding to unused: 68, 64
[47:0], 16'b0 };
// unused = 3, ustr = S_3_01[50:48]
    end
    initial A_4 = 0;
    if(i_reset)
        A_4 <= 1'b0;
    else if (i_ce)
        A_4 <= A_3;
    assign  o_p = S_4_00[(NA+NB-1):0];
    assign  o_aux = A_4;
    // Make verilator happy
    // verilator lint_off UNUSED
    wire    [3-1:0] unused;
    assign  unused = { S_3_01[50:48] };
    // verilator lint_on  UNUSED
`ifdef  FORMAL
    reg f_past_valid;
    initial f_past_valid = 0;
        f_past_valid <= 1'b1;
    wire    [4+1:0] f_auxpipe;
    assign  f_auxpipe   = { A_4,A_3,A_2,A_1,A_0, i_aux };
    initial assume(!i_aux);
    if ((i_reset)||((f_past_valid)&&($past(i_reset))))
        assume(!i_aux);
    initial assert(f_auxpipe == 0);
    if ((f_past_valid)&&($past(i_reset)))
    if ((f_past_valid)&&(!$past(i_reset))&&($past(i_ce)))
        assert(f_auxpipe[4+1:1] == $past(f_auxpipe[4:0]));
    if ((f_past_valid)&&(!$past(i_reset))&&(!$past(i_ce)))
        assert(f_auxpipe[4+1:1] == $past(f_auxpipe[4+1:1]));
    localparam  F_DELAY = 4;
    reg [NA+NB-1:0] f_result;
    integer         ik;
    initial f_result = 0;
    if(i_reset)
        f_result = 0;
    else if (i_ce)
    begin
        f_result = 0;
        for(ik=0; ik<NS; ik=ik+1)
            if(i_a[ik])
                f_result = f_result + { {(NL-ik-1){1'b0}},
                        i_b, { (ik){1'b0} } };
    end
    reg [F_DELAY*(NA+NB)-1:0]   f_result_pipe;
    initial f_result_pipe = 0;
    if(i_reset)
        f_result_pipe <= 0;
    else if (i_ce)
        f_result_pipe <= { f_result, f_result_pipe[((F_DELAY)*(NA+NB)-1):(NA+NB)] };
        assert(o_p == f_result_pipe[(NA+NB-1):0]);
        assume((i_ce)
            ||((f_past_valid)&&($past(i_ce)))
            // ||(($past(f_past_valid))&&($past(i_ce,2)))
`endif
endmodule
bimpy.v
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
// Filename:    bimpy
// Purpose: An unsigned 2-bit multiply based upon the fact that LUT's allow
//      6-bits of input, but a 2x2 bit multiply will never carry more
//  than one bit.  While this multiply is hardware independent, it is
//  really motivated by trying to optimize for a specific piece of
//  hardware (Xilinx-7 series ...) that has 4-input LUT's with carry
//  chains.
// copy.
module  bimpy(i_clk, i_reset, i_ce, i_a, i_b, o_r);
    parameter   BW=18, LUTB=2;
    input       [(LUTB-1):0]    i_a;
    input       [(BW-1):0]  i_b;
    output  reg [(BW+LUTB-1):0] o_r;
    wire    [(BW+LUTB-2):0] w_r;
    wire    [(BW+LUTB-3):1] c;
    assign  w_r =  { ((i_a[1])?i_b:{(BW){1'b0}}), 1'b0 }
                ^ { 1'b0, ((i_a[0])?i_b:{(BW){1'b0}}) };
    assign  c = { ((i_a[1])?i_b[(BW-2):0]:{(BW-1){1'b0}}) }
            & ((i_a[0])?i_b[(BW-1):1]:{(BW-1){1'b0}});
    initial o_r = 0;
        if (i_reset)
            o_r <= 0;
        else if (i_ce)
            o_r <= w_r + { c, 2'b0 };
endmodule
I think it could use more comments.
Dont really see what this has to do with formal verification?
What are the purposes of these two signals in bimpy.v
They are all GPLv3. So, if you use any of them in your project, ou must open your whole code, and your possible patents rigths related to your development are basically null.
I would *never* use any of these codes in a commercial project.
The code also does not match this gate-level diagram , please correct me if wrong
Besides, the following is waveform from bimpy.v for a simple 2x2 unsigned multiplier.
From the code itself, I generated a gate-level representation which again does not match the above gate-level diagram.
Edit: Added comment from one of my friend: the following modification does the same thing with fewer logic !!
o_r <= (i_a[0] ? i_b : 0) + (i_a[1] ? i_b:0)<<1;
Now, let's us appreciate the gate-level circuit comparison between two expression of o_r
So far, the questions are NOTHING to do with formal verification. So whats the question?
There will be one row for every pair of bits in i_a, and each row will contain (AW+3) bits, to allow for signed arithmetic manipulation.
Could anyone explain about the code comment I found in umpy_32x32.v ?
