This circuit will produce AM and FM components as shown below where a 100kHz modulation source is used.
Are you talking about a physical measurement or some simulation results?
If you are doing a physical measurement, please explain your method.
I have a huge river valley and a very sensitive car radio and home stereo. People ask, "How far will it transmit to a cheap clock radio?" I answer, "Across the street".You will be surprised how far you can transmit on only 10mW when there are no obstacles in between.
You should try and rather use the graph simulation than the virtual oscilloscope for this circuit. Using the scope often causes animation problems if not set up 100% in the animation settings.
