Fm modulator message signal amplitude control
akhilpaulv
Full Member level 2
Thrissur, India
Hi ,
I am designing a FM modulator. In the modulator the message signal is fed to VCO but the message signal has amplitude of 200 mV to 5 V vpp i want to reduce to 0 V to 0.025 mV .? Will somebody please suggest any circuit for that.
- Akhil
It depends to some extent on the frequency of the modulation and the impedances involved. If the frequency is low, all you need is a resistive divider with values such that 5V input gives 25uV output.
That is a 200,000:1 reduction in voltage which for most applications would seem excessive, are you sure you have the voltages correct?
Brian.
Using a 25uV (microvolt) modulation signal perhaps you will need a VCO with a gain of thousands of MHz per Volt, which will make it very unstable..
