Twisha
Member level 1
I have a 1.25 kW LDMOS amplifier. It works fine at low powers of about 100 W. But beyond that I see an increase in the display on the power supply for the Gate to Source Voltage and Drain current increases too. The CRO also shows a fluctuating pulse. The output power on the power meter fluctuates a lot too.
Following are the details:
Drain Voltage: 50 V
Gate to Source Voltage : 2.495 V (Increases to 3.8 V by itself in case of fluctuations)
Signal Duty Cycle of 10% (Pulse width : 1mS and PRT: 10 mS)
Drain Current Variation of around 1 A (from 2A to 3A) at maximum power.
If I continue increasing the output power, there is a spark and some smoke and I lose the transistor.
Please help!
Drain Voltage: 50 V
Please help!
