Hello everyone,
I have a COTS 1x8 switch from Pulsar Microwave
View attachment SW8AD.pdf, and it is behaving funny so I wanted to ask some questions.
The switch uses DB15 connector for control/power.
Pin 1 2 3 are used as control bits (000 for port 1 to 111 for port 8), pin 13 14 15 are used for power (5V -5V gnd), and other pins are unused.
For some reason, the switch works when I try to open up port 1 (000), 2(100), 3(010), 5(001), and 7(001), but does not work when I try port 4, 6, and 8.
I first thought it was the first bit that was causing the problem, but it does not seem like it as port 2 opens up...
Does anyone have any idea? Would it be best to just send the switch over to the vendor rather than fixing it myself?
Thank you in advance!
Here is an update.
I literally have not done anything to the switch, and it magically started to work again.
Which is even more frustrating, since it means it only works sometimes, which means it is not reliable...
