Firefly PCB done, (PIC ZIF socket & 16F88 Tutor) drawing
blueroomelectronics
Advanced Member level 5
Toronto, Canada
firefly pcb
Well the Firefly PCB artwork has just been completed. Here's a sketchup drawing of what it will look like.
**broken link removed**[/img]
zif socket
WOW Thats looks great. Which software did you use to create it?
16f88
Thanks, it's called Sketchup https://www.sketchup.com/ Going to play with the browser plugin, I'll put the 3D files on my site if it works.
pcb firefly draw
Hmm.....I see....Does Sketchup has libraries for drawing all those electronic stuff or you have to draw all by yourself?
pcb para zif
hey wat does it do...looks like an icd 2.....can i get sch ...pcb files....
placa para socket zif para pic
very nice picture I have downloded the demo but it look hard to use
I will have to do some playing by the time i get to learn it the trail will run out
i se that it does not come with electronic components
blueroomelectronics are they easy to create ?
cheers
Wizpic
zif socket pic
The firefly is a companion product designed for use with the Inchworm ICD2 (although any ICD / ICP like the JDM should work, as long as it's not a LVP) Here's the schematic for the PCB but since I sell the PCB as a kit I generally don't distribute it. It's also double sided so would be difficult for most to etch.
pic zif socket schema
There is a free Google Sketchup version, search for that.
Here's a preview of some robot drawings I'm working on.
zif 40 pcb package
Hi blueroomelectronics,
Can you tell me how you drew that PCB with SketchUp? Is there any library available for that? A small tutorial would be great for many of us users.
sketchup pcb
blueroomelectronics.....i still dont understad...does it program pics......then its goooooooooooooooooooooooooooooooooooood......................
fire fly pcb
That looks very nice, I have now got the free version to play with,
I have been doing a little playing and i think it is quite easy program to use
How did you create your components, I understabd how you creaated the Cap and resistor bu how did you create the Chip and the chip pins that's one i can not master
cheers
wizpic
Added after 44 minutes:
blueroomelectronics
I am going to be cheecky could you upload or PM me your components That you created for elctronics stuff
I understand if you don't want to i will try and make my own
I have got use to it now
this program is wicked
cheers wizpic
icd2 zif socket schematics
hi
the best electronic pcb and schematic 3d prog are pcbwizard and autotraxeda they are very easy to used and ment for pcb and schematic designing if you need it pm me hxxp://www.new-wave-concepts.com/ed/pw_tour1.html
regards
Fragrance
pcb in sketchup
hi all
eventually i got electronic components fot sketchup
i have 86 3d models
all dip (8 to 40)
resistors & caps
and a lot of things
there is also a web site for computer parts
sockets para pic
Hi all.
I know about EAGLE3D plugin that use POVRAY to drawing th 3D pcbs.
How do you design the PCB? with a plugin or with many time and work?
73
Re: pcb in sketchup
grat.
Do you still have the component 3d for sketchup?
Thank you, bye
Massimo
hi all
i have 86 3d models
all dip (8 to 40)
resistors & caps
and a lot of things
