finite state machine not working as needed
goodpranoy
Junior Member level 3
In the following code if we donot give input before s2 then the state s2 continues indefinitely.
this occurs in the second process(state machine process)
can anyone please suggest a method so that after s2 is reached and when input changes then the state also changes.
library ieee;
use ieee.std_logic_1164.all;
entity mealy is
port (clk : in std_logic;
      reset : in std_logic;
      enter : in std_logic;
      input:in std_logic_vector(2 downto 0);
      pc_enable: out std_logic;
      alu_enable: out std_logic;
      rom_enable: out std_logic;
      reg_enable: out std_logic;
      ir_enable: out std_logic;
      load_a:out std_logic_vector(2 downto 0);
      load_b:out std_logic_vector(2 downto 0);
      sel: out std_logic
end mealy;
architecture behavioral of mealy is
type state_type is (s0,s1,s2,s3,s4,s5,s6,s7,s8,s9,s10,rab,wa,wab,wb,ra);  --type of state machine.
signal current_s,next_s: state_type;  --current and next state declaration.
begin
process (clk,reset)
begin
 if (reset='1') then
  current_s <= s0;  --default state on reset.
elsif (rising_edge(clk)) then
  current_s <= next_s;   --state change.
end if;
end process;
--state machine process.
process (current_s,enter)
begin
  case current_s is
    when s0 =>        --when current state is "s0"
    next_s <= s1;
    when s1 =>       --when current state is "s1"
    next_s <= s2;
    when s2 =>       --when current state is "s2"
    if(input ="000") then
    next_s <= rab;
    elsif(input ="001") then
    next_s <= rab;
    elsif(input ="010") then
    next_s <= rab;
    elsif(input ="011") then
    next_s <= rab;
    elsif(input ="100") then
    next_s <= rab;
    elsif(input ="101") then
    next_s <= ra;
    elsif(input ="110") then
    next_s <= s9;
    elsif(input ="111") then
    next_s <= s10;
    else
    next_s<=s2;
    end if;
    when s3 =>         --when current state is "s3"
    next_s <= wa;
    when s4 =>         --when current state is "s4"
    next_s <= wa;
    when s5 =>         --when current state is "s5"
    next_s <= wab;
    when s6 =>         --when current state is "s6"
    next_s <= wa;
    when s7 =>         --when current state is "s7"
    next_s <= wa;
    when s8 =>         --when current state is "s8"
    next_s <= wb;
    when s9 =>         --when current state is "s9"
    if(enter='1') then
    next_s <= s0;
    else
    next_s <= s9;
    end if;
    when s10 =>         --when current state is "s10"
    next_s <= s0;
    when rab =>       --when current state is "rab"
    next_s <= s3;
    next_s <= s4;
    next_s <= s5;
    next_s <= s6;
    next_s <= s7;
    end if;
    when wa =>         --when current state is "wa"
    next_s <= s0;
    when wab =>         --when current state is "wab"
    next_s <= s0;
    when wb =>         --when current state is "wb"
    next_s <= s0;
    when ra =>         --when current state is "wb"
    next_s <= s8;
end case;
end process;
    output_logic:process(current_s)
    begin
        case current_s is
            when s0=>
                pc_enable<='1';
                alu_enable<='0';
                rom_enable<='1';
                reg_enable<='0';
                ir_enable<='0';
                load_a<="UUU";
                load_b<="UUU";
                sel<='U';
            when s1=>
                pc_enable<='0';
                alu_enable<='0';
                rom_enable<='0';
                reg_enable<='0';
                ir_enable<='0';
                load_a<="UUU";
                load_b<="UUU";
                sel<='U';
            when s2=>
                pc_enable<='0';
                alu_enable<='0';
                rom_enable<='0';
                reg_enable<='0';
                ir_enable<='1';
                load_a<="UUU";
                load_b<="UUU";
                sel<='U';
          when s3=>
                pc_enable<='0';
                alu_enable<='1';
                rom_enable<='0';
                reg_enable<='0';
                ir_enable<='0';
                load_a<="UUU";
                load_b<="UUU";
                sel<='U';
          when s4=>
                pc_enable<='0';
                alu_enable<='1';
                rom_enable<='0';
                reg_enable<='0';
                ir_enable<='0';
                load_a<="UUU";
                load_b<="UUU";
                sel<='U';
         when s5=>
                pc_enable<='0';
                alu_enable<='1';
                rom_enable<='0';
                reg_enable<='0';
                ir_enable<='0';
                load_a<="110";
                load_b<="110";
                sel<='0';
        when s6=>
                pc_enable<='0';
                alu_enable<='1';
                rom_enable<='0';
                reg_enable<='0';
                ir_enable<='0';
                load_a<="UUU";
                load_b<="UUU";
                sel<='U';
        when s7=>
                pc_enable<='0';
                alu_enable<='1';
                rom_enable<='0';
                reg_enable<='0';
                ir_enable<='0';
                load_a<="UUU";
                load_b<="UUU";
                sel<='U';
        when s8=>
                pc_enable<='0';
                alu_enable<='1';
                rom_enable<='0';
                reg_enable<='0';
                ir_enable<='0';
                load_a<="UUU";
                load_b<="UUU";
                sel<='U';
        when s9=>
                pc_enable<='0';
                alu_enable<='0';
                rom_enable<='0';
                reg_enable<='1';
                ir_enable<='0';
                load_a<="110";
                load_b<="UUU";
                sel<='1';
        when s10=>
                pc_enable<='0';
                alu_enable<='0';
                rom_enable<='0';
                reg_enable<='1';
                ir_enable<='0';
                load_a<="101";
                load_b<="UUU";
                sel<='0';
         when wa=>
                pc_enable<='0';
                alu_enable<='0';
                rom_enable<='0';
                reg_enable<='1';
                ir_enable<='0';
                load_a<="110";
                load_b<="UUU";
                sel<='0';
          when wb=>
                pc_enable<='0';
                alu_enable<='0';
                rom_enable<='0';
                reg_enable<='1';
                ir_enable<='0';
                load_a<="UUU";
                load_b<="110";
                sel<='U';
          when rab=>
                pc_enable<='0';
                alu_enable<='0';
                rom_enable<='0';
                reg_enable<='1';
                ir_enable<='0';
                load_a<="101";
                load_b<="101";
                sel<='0';
        when wab=>
                pc_enable<='0';
                alu_enable<='0';
                rom_enable<='0';
                reg_enable<='1';
                ir_enable<='0';
                load_a<="110";
                load_b<="110";
                sel<='0';
        when ra=>
                pc_enable<='0';
                alu_enable<='0';
                rom_enable<='0';
                reg_enable<='1';
                ir_enable<='0';
                load_a<="101";
                load_b<="UUU";
                sel<='U';
  end case;
end process;
end behavioral;
as a side question, why have you assigned load_a and b to uninitialised in some states? 'U' is not a valid option on fpgas
