Finding a suitable LDO
orionsbelt
Junior Member level 2
Hi everybody
I have a LM337-LM, which gets a -12V at its input and will generate -10V at its output.
Similarly, I need a LDO which will get a +12V at its input and needs to generate +10V at the output.
The main constrain is, that I need such a LDO which has the same pin configuration as LM337-LM as well as the same package, i.e. SOIC(D). But SOP package would do just fine.
Thanks in advance.
Regards
OB
Why would you share different build functions in same pads? just to save real estate? for L317 and L337 choice?
Did you read 2.5V min for V diff is recommended? You have only 2V.
