find frequency from a complex number
scdoro
Member level 5
Member level 5
hi all,
suppose i have a complex number of a signal as = 2+3i.
i need to express it in terms of Asin(ωt)
Qn1) how do i calculate the frequency,f of this signal?
Qn2) how di i calculate the amplitude A of this signal?
thanks
regards
scdoro
what do you mean by complex number of a signal? Does that mean that it is the amplitude of the signal at some instant 't' ?
please clarify me
thnx
purna!
Have a look at:
h**p://www.ping.be/~ping1339/complget.htm
The magnitude is sqrt(Re^2+Im^2). The angle is phi=atan(Im/Re). Then you can write the complex number as A*exp(j*phi)=A*(cos(phi)+jsin(phi)).
As mentioned in the previous reply, you have a phasor and your sine wave will be y(t) = A Cos( w x t +theta) where
A = sqrt[real(phasor)^2 + imag(phasor)^2]
theta = phase(signal) = atan(imag/real)
However, this phasor representation is used when the circuit is working at a known frequency W so you cannot extract your frequency (W) from the phasor.
Regards - TS
Hi again,
see attachment for my actual question.
I have found the result of the FFT of x is found to be
[0,-0.83536j,0,0.1464j,0,-0.1464j,0,0.8536j].
From here we can see that it is made up of 2 sine wave components.
given by x(t) = Asin(2Πf1t) + Bsin(2Πf2t).
Q1)And now i need to determine A,B,f1 and f2. How do i make use of the result i got which is in complex numbers to find those values A,B,f1 and f2?
Q2) and explain how the negative freq is represented in this FFT?
thanks
regards
scdoro
