finaltimeOP error in cadence
sweeta71
Newbie level 2
I am trying to design a magnetic tunnel junction. I got the following error. can any one please help?
Something is not converging but information you gave just tells this nothing more. So I can't pin down what exactly is problematic.
A very easy way out of DC convergence issues, if you are using an unknown model, is assigning initial conditions for your circuit. It's probable that the model you are using has open circuits at initial step so those nodes are having trouble during DC op analysis. Set up initial conditions and try again if this is all the information you can provide.
Some other things that you can look at are the model itself and checking if you are putting the magnetic tunnel junction under sane conditions.
i did not understand properly as i know only basics of cadence . I found the following code of MTJ in net and i have attached the schematic diagram used. I just dont know where it has gone wrong.
`resetall
`include "constants.vams"
`include "disciplines.vams"
`define explimit 85.0
`define exp(x) exp(min(max((x),-`explimit),`explimit))
`define sqrt(x) pow( (x), 0.5)
//Shape definition
`define rec 1
`define ellipse 2
`define circle 3
Electrical Constants
/*----------Elementary Charge---------------*/
`define e 1.6e-19
/*----------Bohr Magnetron Costant----------*/
`define ub 9.27e-28
/*----------Boltzmann Constant------------- */
`define Kb 1.38e-23
/*----------Electron Mass------------- */
`define m 9.10e-31
/*----------Euler's constant---------------*/
`define C 0.577
module Model(T1,T2,x,Ttrans,PI,Temp);
inout T1, T2;
electrical T1, T2;
electrical n1,n2;
  //virtual terminals of RC circuit for time modelisation for temperature
/*----------X=store the state of the MTJ, non-volatile way------------- */
/*----------Ttrans=store the state of the MTJ with time influence, non-volatile way------------- */
/*----------PI=switching probability------------- */
/*----------Temp=store the temperature------------- */
inout x,Ttrans,PI,Temp;
electrical x,Ttrans,PI,Temp;
MTJ Technology Parameters
(Corresponds to the HITACHI MTJ Process)
/*----------Gilbert Damping Coefficient---------------*/
parameter real  alpha=0.027;
/*----------GyroMagnetic Constant in Hz/Oe---------------*/
parameter real  gamma=1.76e7;
/*----------Electron Polarization Percentage % ---------------*/
parameter real  P=0.52;
/*----------Out of plane Magnetic Anisotropy in Oersteds---------------*/
parameter real  Hk=1433;
/*----------Saturation Field in the Free Layer in Oersteds---------------*/
parameter real  Ms=15800;
/*----------The Energy Barrier Height for MgO in electron-volt---------------*/
parameter real  PhiBas=0.4;
/*----------Voltage bias when the TMR(real) is 1/2TMR(0) in Volt---------------*/
parameter real  Vh=0.5;		//experiental value with MgO barrier
Device Parameters
(Corresponds to the HITACHI 240 x 80 MTJ)
/*----------Height of the Free Layer  in nm---------------*/
parameter real  tsl=1.3e-9 from[0.7e-9:3.0e-9];
/*----------Length in nm---------------*/
parameter real  a=40e-9;
/*----------Width in nm---------------*/
parameter real  b=40e-9;
/*----------Radius in nm---------------*/
parameter real  r=20e-9;
/*----------Height of the Oxide Barrier in nm---------------*/
parameter real  tox=8.5e-10 from[8e-10:15e-10];
/*----------TMR(0) with Zero Volt Bias Voltage ---------------*/
parameter real  TMR=0.7;
/*----------Shape of MTJ---------------*/
parameter real 	SHAPE=2  from[1:3];  //SQUARE
/*----------Neel-Brown model parameter ---------------*/
parameter real 	tau0=8.7e-10;	//experiental value, prototype Hitachi 2007m with CoFe layer
/*----------Error probability Ps=1-Pr(t) ----------------*/
parameter real	Ps=0.999999;
/*----------Threshold for Neel-Brown model----------------*/
parameter real brown_threshold=0.0;
/*----------MTJ State Parameters----------------*/
/*----------Initial state of the MTJ, 0 = parallele, 1 = anti-parallele----*/
parameter integer 	PAP=1 from[0:1];
/*----------Room temperature in Kelvin----------------*/
parameter real 		T= 300;//$random % 50 +323;
/*----------Resistance area product in ohmum2----------------*/
parameter real 		RA=5 from[5:15];
parameter real Pwidth=2e-8;
/*----------Parameters of RC circuit for time modelisation for temperature---------------*/
/*----------Heat capacity per unit volume in J/m3*K----------------*/
parameter real 		Cv= 2.74e6  from[2.735e6:2.7805e6];
/*----------Thermal conductivity of the thermal barrier(MgO) in W/m*K----------------*/
parameter real 		lam= 84.897 from [84.8912:84.9449];//
/*----------Total thickness of MTJ nanopillar in nm----------------*/
parameter real 		thick_s= 3.355e-8;//
/*----------RC circuit for time modelisation for temperature---------------*/
parameter real resistor=100e6; //R=100M
parameter real coeff_tau=12; //Coefficient to increase tau_th
real capacitor;   //virtual capacitor
real tau_th;        //characteristic heating/cooling time
real temp;    //real temperature of MTJ
real temp_init;   //temperature initialised
real R;		//resistance of MTJ
real delay;
parameter real p=1.0;
parameter integer STO=0 from[0:2];         //choice of stochastic dynamic, 0 no stochastic, 1 random exponential distribution,2 random gauss distribution
parameter integer RV=0 from[0:2];          //choice of stochastic static intrinsically, 0 no stochastic, 1 random uniform distribution,2 random gauss distribution
parameter integer Temp_var=0 from[0:1];     //choice of time modelisation for temperature
parameter real DEV_tox=0.03;        //choice of standard deviation of stochastic static gauss distribution for tox when RV=2
parameter real DEV_tsl=0.03;        //choice of standard deviation of stochastic static gauss distribution for tsl when RV=2
parameter real DEV_TMR=0.03;        //choice of standard deviation of stochastic static gauss distribution for TMRwhen RV=2
parameter real STO_dev=0.03;        //choice of standard deviation of stochastic dynamic gauss distribution when STO=2
//variables
//Polaristion constant for the two states of STT-MTJ
real PolaP; 	//Polarization state parallel of STT-MTJ
real PolaAP; 	//Polarization state anti-parallel of STT-MTJ
real surface;	//Surface of MTJ
//Critical current density for the two states of STT-MTJ
real gp; 	//Critical current density for P state
real gap;	//Critical current density for AP state
real Em,EE; 	//Variable of the Slonczewski model
//TMR real value for the two states of STT-MTJ
real TMRR;	//TMR real value for P state
real TMRRT;	//TMR real value for AP state
//Resistance of MTJ
real Ro;	//Resistance of MTJ when bias voltage = 0V
real Rap;	//Resistance value for AP state
real Rp;	//Resistance value for P state
//Voltage of MTJ
real Vb;	//V(T1,T2)
real Vc;	//V(T2,T1)
real Id;	//Current of MTJ
//critial current for the two states of STT-MTJ
real IcAP; 	//Critial current for AP state
real IcP;	//Critial current for P state
real ix;	//Current used to store the state of the MTJ
real tau;	//Probability parameter
real FA; //Factor for calculating the resistance based on RA
integer seed;	//Used to initialize the random number generator
//Stochastic effects
real durationstatic,duration;	//time needed to be sure that the switching is effected
real toxreal;   //real thickness of oxide layer
real tslreal;	//real thickness of free layer
real TMRreal;	//real TMR
real pp;
(*cds_inherited_parameter*)parameter real seedin = 0;  //generation of a real random value of seed for random distribution function modified 20140223
real VPI;
real P_APt;
real AP_Pt;
real NP_APt,NAP_Pt;
integer counter;
analog begin
	if (SHAPE==1)
		begin
		surface=a*b;	//SQUARE
		end
		else if (SHAPE==2)
		begin
		surface=`M_PI*a*b/4;	//ELLIPSE
		end
		else
		begin
		surface=r*r;    //ROUND
	end
	Vc=V(T2,T1);	//potential between T2 and T1
	Vb=V(T1,T2);	//potential between T2 and T1
//initial conditions
@(initial_step)
begin
	counter=0;
	seed=1000000000*seedin;	//initialization of seed modified 20140516
	FA=3322.53/RA;	//initialization of resistance factor according to RA product
	if (RV==1)
		begin
			//real thinkness of oxide layer, free layer and real TMR considering the random distribution(uniform distribution)
			toxreal=$rdist_uniform(seed,(tox-tox*DEV_tox),(tox+tox*DEV_tox));
			tslreal=$rdist_uniform(seed,(tsl-tsl*DEV_tsl),(tsl+tsl*DEV_tsl));
			TMRreal=$rdist_uniform(seed,(TMR-TMR*DEV_TMR),(TMR+TMR*DEV_TMR));
		end
	else if (RV==2)
		begin
			//real thinkness of oxide layer, free layer and real TMR considering the random distribution(gauss distribution)
			toxreal=abs($rdist_normal(seed,tox,tox*DEV_tox/3));
			tslreal=abs($rdist_normal(seed,tsl,tsl*DEV_tsl/3));
			TMRreal=abs($rdist_normal(seed,TMR,TMR*DEV_TMR/3));
		end
	else
		begin
			toxreal=tox;
			tslreal=tsl;
			TMRreal=TMR;
		end
	temp=T;
        temp_init=T;
        tau_th= Cv*thick_s / (lam/thick_s);
        capacitor=coeff_tau*tau_th/resistor;	//tau_th=resistor*capacitor
	Ro=(toxreal*1.0e10/(FA*`sqrt(PhiBas)*surface*1.0e12))*exp(1.025*toxreal*1.0e10*`sqrt(PhiBas));	//resistance
	Em=Ms*tslreal*surface*Hk/2;
	duration=0.0;
        if(analysis("dc"))
	    begin
	      //States inititialisation
	      ix=PAP;
	    end
        else
	    begin
	      ix=-PAP;
	      I(x)<+ PAP;
	      VPI=p;
	      I(PI)<+p;
	    end
        I(Ttrans)<+ -PAP;
       // I(T1,T2)<+ Id;	//Actualisation of the current of MTJ with the value calculated
end
if(Temp_var==0)
   begin
      temp=temp_init;        //temperature constant
   end
else
   begin
      temp=V(Temp);          //time modelisation for temperature
   end
EE=Em/(`Kb*temp*40*`M_PI);  //result of E/kbT
if(analysis("dc"))
	begin
		if(ix==0)	//Case which the magnetizations of the two layers are parallel
			begin
				TMRR=TMRreal/(1+Vb*Vb/(Vh*Vh));
				//Parallel resistance
				Rp=Ro;
				R=Rp;
				Id=Vb/Rp;
				//Calcul of critical current
				PolaP=`sqrt(TMRreal*(TMRreal+2))/(2*(TMRreal+1));  	//Polarization state parallel
				gp=alpha*gamma*`e*Ms*tslreal*Hk/(40*`M_PI*(`ub*PolaP)); 	//Critical current density
				IcP=gp*surface;
                                //$display("gp=%g",gp);
				if(Vb<(IcP*Rp))
					begin
						ix=0.0;
					end
				else
					begin
						ix=1.0;
					end
			end
		else
			begin
				//TMR real
				TMRRT=TMRreal/(1+Vb*Vb/(Vh*Vh));
				// Antiparallel resistance
				Rap=Ro*(1+TMRRT);
				Rp=Ro;
				R=Rap;
				Id=Vb/(Rap);
				PolaAP=`sqrt(TMRreal*(TMRreal+2))/(2*(TMRreal+1));  	//Polarization state anti parallel
				gap=alpha*gamma*`e*Ms*tslreal*Hk/(40*`M_PI*(`ub*PolaAP));  	//Critical current density
				IcAP=gap*surface; 	// Critical current
				if(Vc>=(IcAP*Rap))
					begin
						ix=0.0;
					end
			end
                V(Ttrans)<+ix;
                I(T1,T2)<+Id;	//Actualisation of the current of MTJ with the value calculated
        end
else
	begin
        if(STO==1||STO==2)    //considering the stochastic behaviors
          begin
	    if(I(Ttrans)>-0.5)	//Case which the magnetizations of the two layers are parallel
		begin
			if (pp==1)
				begin
					VPI=1;
					pp=0;
				end
			//TMR real
			Rp=Ro;
			R=Rp;
			Id=Vb/Rp;
			if(ix==0)		//Dynamic=parallel state,static=parallel state
				begin
					IcP=gp*surface;		// Critical current
					if(Vb>=IcP*Rp)
						begin	//Current higher than critical current
							//STT-MTJ dynamic behavior : Sun model
							//Time needed to be sure that the switching is effected
							durationstatic=(`C+ln(`M_PI*`M_PI*(Em/(`Kb*temp*40*`M_PI))/4))*`e*1000*Ms*surface*tslreal*(1+P*P)/(4*`M_PI*2*`ub*P*10000*abs(Id-IcP));
						        $display("durationstatic=",durationstatic);
							if(STO==1)
								begin
									duration=abs($rdist_exponential(seed, durationstatic));	//stochastic effect(exponential distribution)
								end
							else if(STO==2)
							        begin
									duration=abs($rdist_normal(seed,0.995*durationstatic,durationstatic*STO_dev/3));	//stochastic effect(gauss distribution)
								end
							else
								begin
									duration=durationstatic;
								end
							if(duration<=Pwidth)
								begin	//Switching of the free layer always occurs
									if(duration>VPI)
										begin
											ix=-1.0;   //change the current state of MTJ
											pp=1;
										end
									else
										begin
											VPI=duration;
											duration= 100000000;
										end
								end
						end
					else
						begin	//Current smaller than critical current
				    			ix=0.0;	//save the current state of MTJ
							//STT-MTJ dynamic behavior : Neel-Brown model
							tau=tau0*exp(Em*(1-abs(Id/IcP))/(`Kb*temp*40*`M_PI));
							if(Vb>brown_threshold)
								begin
									if (Vb<0.8*IcP*Rp)
										begin
											if(STO==1||STO==2)
												begin
													duration=abs($rdist_exponential(seed, tau));	//stochastic effect
												end
											else
												begin
													duration=tau;
												end
											if (Pwidth >= duration)
					  							begin
													if(VPI<=duration)
														begin
														end
													else
														begin
															VPI=duration;
														end
												end
										end
								end
						end
				end
	              end
	 else if(I(Ttrans)<-0.5)  	//Case which the magnetizations of the two layers are antiparallel
		begin
			if (pp==1)
				begin
					VPI=1;
					pp=0;
				end
//TMR real
			Rap=Ro*(1+TMRRT);
			Rp=Ro;
			R=Rap;
			Id=Vb/(Rap);
			if(ix==0)
				begin
					if(Vc>=(IcAP*Rap))
							durationstatic=(`C+ln(`M_PI*`M_PI*(Em/(`Kb*temp*40*`M_PI))/4))*`e*1000*Ms*surface*tslreal*(1+P*P)/(4*`M_PI*2*`ub*P*10000*abs(-Id-IcAP));
							if(STO==1)
								begin
								end
							else if(STO==2)
							        begin
			                                        end
							else
								begin
								end
									if(VPI<=duration)
										begin
											ix=0.0;   //change the current state of MTJ
											pp=1;
										end
									else
										begin
											VPI=duration;
											duration= Pwidth;
										end
								end
						end
					else
	    						ix=-1.0;	//save the current state of MTJ
							tau=tau0*exp(Em*(1-abs(Id/IcAP))/(`Kb*temp*40*`M_PI));
							if(Vc>brown_threshold)
								begin
									if (Vc<0.8*IcAP*Rap)
										begin
											if(STO==1||STO==2)
												begin
        end
											else
												begin
													duration=tau;
												end
											if (duration<=Pwidth)
					  							begin
													if(VPI<=duration)
														begin
														end
													else
														begin
															VPI=duration;
														end
												end
										end
								end
						end
				end
	           end
         end
     else                          //without consideration of stochastic behaviors
            begin
		    begin
			if (pp==1)
				begin
					VPI=1;
					pp=0;
				end
			//TMR real
			Rp=Ro;
			R=Rp;
			Id=Vb/Rp;
					if(Vb>=IcP*Rp)
								end
							else
								begin
									ix=0.0;
								end
						end
					else
								begin
									if (Vb<0.8*IcP*Rp)
										begin
											duration=tau;
					  							begin
												end
											else
												begin
													ix=0.0;
												end
										end
								end
						 end
	               end
		     begin
			if (pp==1)
				begin
					VPI=1;
					pp=0;
				end
			//TMR real
			Rap=Ro*(1+TMRRT);
			Rp=Ro;
			R=Rap;
			Id=Vb/(Rap);
					if(Vc>=(IcAP*Rap))
							duration=durationstatic;  //time needed to be sure that the switching is effected
								end
							else
								begin
									ix=-1.0;
								end
						end
					else
								begin
										begin
											duration=tau;
					  							begin
												end
											else
												begin
													ix=-1.0;
												end
										end
								end
						end
	             end
           end
           I(x)<+ix;	//Actualisation of the state of x with the value calculated
           if(counter==0)
	     begin
	       if(I(Ttrans)!=0)
	           begin
		         ix=0;
		   end
             end
	   I(Ttrans)<+ transition(ix,duration,1e-11,1e-11); //Ttrans has the same function than x but it includes the time effects
           if(counter==0)
	     begin
	       if(I(Ttrans)!=0)
	           begin
		         ix=-1;
		   end
             end
           I(PI)<+VPI;
	   counter=counter+1;
      end    //la fin de transient analysis
      if(Temp_var==1)
                begin
                     V(n1) <+ ( V(T1,T2)*V(T1,T2) )/ ( R*surface*lam/(thick_s ));   //Definition of the maximum incrase of temperature
                     I(n1,n2) <+ V(n1,n2) / resistor;	// RC circuit definition,RC circuit parallel
                     I(n2) <+ capacitor * (ddt(V(n2)));
                     V(Temp) <+  V(n2) + temp_init;
                end
           else
               begin
                     V(Temp) <+  temp_init;
               end
    // $display("The resistance R=",R);
    // $display("The current Id=",Id);
    // $display("Parallel to antiparallel critical current IcP=",IcP);
    // $display("Antiparallel to parallel critical current IcAP=",IcAP);
   end  //la fin d'analog begin
endmodule
