Final Year Project: Design Zigbee Antenna 2.4G
kurt113
Newbie level 1
Newbie level 1
zigbee antenna
Hello all
I am new here and sorry for stupid questions.
I am now hurrying my final year project
to design antenna for Zigbee
with IE3D
Questions:
1. Which one is good? Dipole, Inverse-F, Patch?
2. What is the antenna special for Zigbee?
3. Is the antenna for Zigbee same as Bluetooth?
4. How can I get some IE3D antenna samples?
Please help..
Thanks
Kurt:|
Added after 12 minutes:
My Uni provides me some selections of substrate
Please see photo for the choices..
Which one is best for designing the Zigbee antenna?
THXX x 10000000
zigbee project
Read some application notes from frescale freescale.com In rf section about zigbee transceiver You can find lot information about design of pcb antennas for 2.4GHz
Gorkin.
    V
zigbee projects
i think zigbee antenna needn't too wide bandwidth so you can use patch or pifa
projects on zigbee
Check out the standard IEEE 802.15.4, there are useful stuff on the antenna. I built an application with it a while ago using CC2430.
A good point to know is that Chipcon has proposed an antenna for zigbee. Check the application note of CC2430. It's very good, I haven't tried it, but I am sure it works.
I can email you the AP if you have any problem downloading it.
Wait wait, I'll attach their design.
Take care
zigbee antenna design
And the values
zigbee chip antenna
Dear Kurt,
Are you come from CityU of Hong Kong ?
I am for the FYP of this year, however, it is the "Antenna for Wimax". Would you mind sending me the reference received 2 years ago ? I am in urgent way at this timing ... ...
Thanks !
2.4g antenna design
Normally those printed antennas indicated by ZigBee chip companies present very poor performance.
You should investigate other (bigger) antennas if the range of the Zigbee is too short. I guess patch antenna is Ok (though the small band it has might be a problem). Pifa is also good, but I would go for a 3D one, not printed.
