I want to calculate FFT of low frequency analog signal for my project. Can you please suggest a suitable microcontroller for the same. I found out about PIC32mx family. Would that be recommendable?If yes then which of PIC32mx seires controller would you suggest?
I found MSP430 useful but its not easily available. Moreover its a mixed signal processor which requires separate programmer to dump the code. I want to use a controller for which universal programmer would do. Can you please give some suggestions regarding this?
dear horace1 can you tell that any extra software will be required for DM330013 (Microstick development board) ?
I want to buy it. I am very thankful to you.
Its a good solution for learning dsPic i think.
I want to start learning dsPIC
Thanks once again.
You will also need a programmer. I think you can use the pic kit 2, or spend a little more and get the ICD2 which have many debugging features and very fast programming. Or you can build your own
