Sep 17, 2006 #1 J Jim cage Full Member level 2 Joined Jul 2, 2006 Messages 149 Helped 13 Reputation 26 Reaction score 6 Trophy points 1,298 Activity points 2,185 bsim3 lambda Hi, Does anybody knows what is the lambda on the Bsimv3.3? The motivation for the question is to find out the output resistance of a mos transistor which is : ro=1/lambda*Id. It seems that the bsimv3.3 manual does not specifiy this lambda value. Can anyone help me? Thanks
Sep 18, 2006 #2 J Jim cage Full Member level 2 Joined Jul 2, 2006 Messages 149 Helped 13 Reputation 26 Reaction score 6 Trophy points 1,298 Activity points 2,185 bsim3 output resistance channel length modulation anybody?
Sep 18, 2006 #3 N noiseless Full Member level 3 Joined May 24, 2005 Messages 172 Helped 15 Reputation 30 Reaction score 6 Trophy points 1,298 Activity points 2,495 jfet lambda calculate there is no such parameters in the Bsim3.3. However, you can get it from the ID vs. VD curves as it defined.
Oct 6, 2006 #4 G Grig Full Member level 4 Joined Sep 3, 2004 Messages 220 Helped 36 Reputation 72 Reaction score 12 Trophy points 1,298 Activity points 1,469 output resistance ads Hi lambda is simplification You should simulate IV interpolate with line and obtain lambda It is good for hand calculation but is not exact.
Oct 6, 2006 #5 khouly Advanced Member level 5 Joined Oct 20, 2003 Messages 2,350 Helped 461 Reputation 916 Reaction score 102 Trophy points 1,343 Location EGYPT Activity points 13,242 output resistance= lambda id lambda is the channel length modulation factor , but it isn't in BSIM3v3 it is in level one mosfet model , for hand calculations khouly
