ferrite based power divider
Electron3
Junior Member level 2
how to design a power divider with ferrite beads
at 10-100MHz frequency for max 1 watt power
Power dividers can use transmission line stubs or transformers. Do you see any literature references for implementation with "ferrite beads"?
yes i am having litreture
FVM is right that the circuit in your pic will never do wideband, but I have seen similar using binocular (2-hole) ferrites and bifilar wire. I'm uncertain those will handle 1Watt.
i tried similar design but didn't find even narrow band from prototype what should be the approach with ferrites
The "ferrite" is actually a RF inductor, I guess with a powder core. It's forming a 100:50 ohm matching circuit together with the capacitors.
Your bandwidth of 10-100 MHz can never be reached with ferrites
We should quickly clarify the terms. In the post #3 design, "ferrite based" actually means lumped LC, specifically based on single pi-filter. As said it can't be wideband.
A transformer based 10 - 100 MHz power divider would be well possible using ferrites, using the basic circuit linked in post #4. Another approach would be a multi-section lumped LC circuit, the lumped equivalent of a multi section transmission line Johnson power divider. It could possibly use ferrite core inductors.
Okay, I was being premature. When building a power divider, I was thinking of using some kind of transformer with 2 secondary windings. Most ferrites have a limited bandwidth. When looking at the amidon datasheets for example, I would look at ferrite type materials. Material 43 runs from 1-50 MHz and material 61 goes from 10-200.
Specs at **broken link removed**
Regards,
Joop
at 64 Mhz
give me idea about this one
