Feeding DMM with 5V source instead of batteries.
T
treez
We have a mastech MS3229 DMM.
It uses 3 AAA batteries, but doesn’t indicate when the batteries are going flat, -the readings just get inaccurate.
We want to supply it with a DC power supply instead. We don’t have a schem for the meter, but do you reckon we’ll be ok feeding it a 5V source, with a single diode to drop down to approx. 4.5V?
Its difficult to say when we don’t know whats inside it.
https://www.amazon.com/MASTECH-MS8229-Multimeter-Temperature-Humidity/dp/B0094DH8UO
I agree.
Thus I recommend to use an DCDC converter to get high impedance isolation.
Klaus
Reactions: treez
    T
Agree with the isolation that Klaus has mentioned. Particularly if you are attempting to measure mains referred voltages while powering from the DC power supply.
Medical-grade supplies have very low leakage currents
Reactions: treez
    T
A transformer style "wall wart" and a LM317 ought to do the
job for the cost of scrap and a shilling (do you guys still have
shillings?). Might want to test what the accurate-as-spec'd
supply voltage range realli is, and tweak the LM317 feedback
network to center up. If you do this first then maybe it says
a 78L05 is am even cheaper option. Maybe check supply draw
across operating modes (like resistance, low range) while
you're at it.
Reactions: treez
    T
Batteries are isolated and low noise. I wonder how well it will adapt to a supply with common mode and differential noise it would otherwise never see.
For medium cost DMM’s extech or BK Precision would be my choice.
We have a plug-in Mastech that drives me insane with its 15-minute power-down feature that cant be disabled. I swear it shares a board with a handheld and they couldn’t be bothered to make this single change.
Reactions: treez
    T
True; very annoying but it is also messy to use an external power supply. I do not understand why they cannot incorporate a low-bat indication.
Reactions: treez
    T
