RohanDey
Member level 2
Hello,
I have been using a simple 433 MHz ASK RF module for some time to transmit data between one TX and one RX. Now I have a requirement where I will need 2 TX module and 4 RX modules, where each TX module will communicate with 2 RX modules. The entire setup will be placed for testing in the same room.
In the software side; I am going to use an unique ID for each receiver. There is a possibility, that both the TX modules may transmit simultaneously, but never with same data.
My question is, when both TX modules transmit simultaneously, obviously it will create an interference in the signal. Then is there a possibility where I can retrieve the received data correctly from this signal?
Any ideas regarding this or any alternative technique is highly appreciated.
Thanks,
Rohan
Thanks,
Rohan
