nabla101
Junior Member level 3
Hi all,
I've been looking at UWB radio, and I have found that the FCC has allocated a mask of allowable EIRP spectral density for the UWB band, and I was wondering if this restriction still applies if I am operating equipment inside an environment such as a grounded metal cage, where it is unable to pass to the outside, and therefore unable to cause interference to other RF equipment.
I was hoping I might be able to operate the equipment at a higher power than is allowed by the FCC UWB mask, and wondered if there was any particular law someone could point me to regarding the matter.
For example can I obtainn a license to commercially release the equipment, on the grounds that it is only supposed to be used inside such an environment, even though there is the possibility of the customer using a transmitter in an open environment, which is out of our control?
Thanks
Thanks
