FCC band-edge test for 802.11b, 802.11g and 802.11a
crenyen
Member level 4
Can anyone tell me the FCC band-edge test spec. for 802.11b, 802.11g and 802.11a and how to slove the band-edge problem?
Because my AP Router failed in this certification item and I still can not find way to solve this problem.
Best Regard
Thanks
biff44
Advanced Member level 5
New England, USA
fcc band edge
Well, basically the power outside of the allowed frequency band exceeded the level specified by the FCC. You make the test with a spectum anlyzer while the wireless card is doing its thing.
You may be missing the spec because:
You are overmodulating, or not filtering the transmitted signal (usually digitally filtered) enough
You need a tighter RF filter somewhere
You are overdriving the output amp and it is generating spectrum regrowth
Your center frequency might be drifting too low or high, and spilling energy out-of-band
You could have mistakenly programmed the wireless card to use a frequency outside of those allowed in the US
venu.gongal
Member level 5
INDIA
Re: FCC band-edge test
Hi Biff
How are the Band edge conducted emissions measured??
Can we compare Band edge Conducted emissions and Radiated emissions??
FvM
Super Moderator
Staff member
Bochum, Germany
FCC band-edge test
Conducted emíssions are measured up to 30 MHz according to most EMC standards, they are typically not a problem
with GHz wireless devices, and also not related to band edges. Generally, detailed measurement methods are specified
in all respective standards (FCC, ETSI, EN).
