May 5, 2009 #1 S sadeepa Junior Member level 1 Joined Jun 4, 2008 Messages 15 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,381 fbus commands I'm going to interface a PIC with nokia 3310. Can anybody tell me whats the relationship between FBUS & AT Commands? There's another thing called PDU & Text format I'm confused with those words. Thanks
May 5, 2009 #2 A are Advanced Member level 4 Joined Nov 16, 2004 Messages 109 Helped 17 Reputation 34 Reaction score 11 Trophy points 1,298 Location Balen (Belgie) Activity points 644 at_command_set_for_nokia_gsm_products AT Commands are ASCII codes. Nokia FBUS is a protocol. For FBUS look at **broken link removed** **broken link removed** http://www.mytutorialcafe.com/Microcontroller Project Thesis Nokia.htm or for AT Commands http://www.seguridadmobile.com/blue...les/AT_Command_Set_For_Nokia_GSM_Products.pdf
May 8, 2009 #3 S sadeepa Junior Member level 1 Joined Jun 4, 2008 Messages 15 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,381 fbus at commands are said: AT Commands are ASCII codes. Nokia FBUS is a protocol. For FBUS look at **broken link removed** **broken link removed** http://www.mytutorialcafe.com/Microcontroller Project Thesis Nokia.htm or for AT Commands http://www.seguridadmobile.com/blue...les/AT_Command_Set_For_Nokia_GSM_Products.pdf Click to expand... Thanks mate I understood little bit. I have some problems.Now phones like 3310 are not available.What are the other phones supporting FBUS which is commonly available? The other problem is when I send a sample frame (get H/W & S/W version) to phone the phone will reply with two frames. First frame is the acknowledge & the other is the data frame requested by us. I want to know whats the time interval between these two frames?
Feb 14, 2010 #4 shouvikroy Member level 1 Joined Jan 27, 2010 Messages 33 Helped 5 Reputation 16 Reaction score 5 Trophy points 1,288 Location India Activity points 1,457 Search the forum to find out more about phones supporting FBUS. There has been a lot of discussion on this topic.
Jan 10, 2011 #5 S swapnsan Newbie level 1 Joined Jan 10, 2011 Messages 1 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,284 hi, u can use nokia 1280.. that will help you it has fbus communication port under the sim slot. U can also get f bus cable for the same from local market. Swapnil
Oct 9, 2012 #6 A ALMIGHTY TECH Member level 3 Joined Jul 5, 2011 Messages 63 Helped 4 Reputation 8 Reaction score 4 Trophy points 1,288 Activity points 1,664 have you ever try it with nokia 1280.. than kindly let us know.. i have try to communicate with 1280. and also it gives reply with hw/sw version. but not able to make or receive call/sms.
