Fatal Run-Time error Dereference of null pointer
lahrach
Full Member level 3
Full Member level 3
Hi friends,
I'm using LabWindows/CVI for my project
How can I resolve this error: Fatal Run-Time error Dereference of null pointer
regards
A null-pointer dereference takes place when a pointer with a value of NULL is used as though it pointed to a valid memory area.
So do chl whether the pointer is supposed to store any value otherwise chk for some lines where the memory of the pointer is removed
Do also chk if that is the actual pointer variable you are using
