qwerty_asdf
Member level 4
This is my ram implementation:
If the address_widht is 3, and data_size is 8 everything works perfect.
With the number above I am getting this error:
and in my simulation window ram_block is NULL array.
Can anyone help me on that?
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
ENTITY ram2 IS
GENERIC
ADDRESS_WIDTH : integer := 14;
DATA_WIDTH : integer := 24
PORT
clock : IN std_logic;
data : IN std_logic_vector(DATA_WIDTH - 1 DOWNTO 0);
write_address : IN integer range 0 to 100;--std_logic_vector(ADDRESS_WIDTH - 1 DOWNTO 0);
read_address : IN integer;--std_logic_vector(ADDRESS_WIDTH - 1 DOWNTO 0);
we : IN std_logic;
q : OUT std_logic_vector(DATA_WIDTH - 1 DOWNTO 0)
END ram2;
ARCHITECTURE rtl2 OF ram2 IS
TYPE RAM IS ARRAY(0 TO 2 ** ADDRESS_WIDTH - 1) OF std_logic_vector(DATA_WIDTH - 1 DOWNTO 0);
SIGNAL ram_block : RAM;
BEGIN
PROCESS (clock)
BEGIN
IF (clock'event AND clock = '1') THEN
IF (we = '1') THEN
--ram_block(to_integer(unsigned(write_address))) <= data;
ram_block(write_address) <= data;
q <= ram_block(read_address);
END IF;
--q <= ram_block(to_integer(unsigned(read_address)));
--q <= ram_block(read_address);
END IF;
END PROCESS;
END rtl2;
Fatal: (vsim-3738) (vopt-1154) No index value can belong to null index range 0 to -1.
# Time: 1920850 ns Iteration: 1 Process: /tb_landmark_1/uut/write_res/#MERGED#line__27,27,27 File: C:/modeltech_6.5/examples/ram2.vhd
# Fatal error in Block write_res at C:/modeltech_6.5/examples/ram2.vhd line 32
