Failed to start cdsdoc, please help !!!
jonna
Newbie level 1
Newbie level 1
cdsdoc
Hi everyone,
I have installed cadence IC 610 in Redhat ES 5,
When i try to start cdsdoc, i get the following error :
"error while loading shared libraries: libpthread.so.0: cannot open shared object file: No such file or directory
although libpthread.so.0 is in /lib directory, (/lib is set into $path already)
Anyone can help me out this trouble ?
tHank you
Added after 13 minutes:
problem solved! for anyone who get this problem.
locate cdsdoc, then comment the line
export LD_ASSUME_KERNEL=2.2.5
Added after 33 minutes:
Hi, I still get problem with cdsdoc. When trying to read any document, i get the error
fail to start CDSDOC server obServer
in the console
xxx/bin/obServer: error while loading shared libraries: libnsl.so.1: cannot open share object ...
An error that's pretty similar to error above. But I could not edit obServer file, it's a binary file. Any suggestion ?
cdsdoc java
You may try to edit the script file of "cdsdoc".
In script "cdsdoc", it set LD_ASSUME_KERNEL to some value according the os version it detects. May be it is set to a wrong value. The environment variable will be inherited by the child process "obServer".
cdsdoc libpthread.so.0
Hi ,
You might need to find the library missing or install the patches for the RHEL5.
BTW it is good is you can check cadence lifecycle..I am not sure they support RHEL 5.
I had similar problem before with RHEL 5.
Good luck.
cdsdoc
hi guys
i have the same problem,have you solved?
libc6.1-1.so.2 ubuntu
Sorry to bump this thread again.
I have the same problem, and it is NOT resolved with changing "LD_ASSUME_KERNEL" variable:
11:43am [centos-lap-roli]> setenv LD_ASSUME_KERNEL 2.4.1
11:43am [centos-lap-roli]> cdsdoc
/bin/sh: error while loading shared libraries: libdl.so.2: cannot open shared object file: No such file or directory
Has anybody solved ?
libpthread.so.0 and cdsdoc and centos
try ln -s /lib/*** cadence_install_path/tools/lib/***
*** is the lib missing
but remeber to do the backup first...
cdsdoc edaboard
I tried that, but still does not work. Did anyone figure this out?
Thx,
edaboard libstdc++-libc6.1-1.so.2
I got the same problem with you. After go through your discussion, I checked cdsdoc again and solve the problem, hope these steps can help you.
1. locate cdsdoc
2. Goto /CDS_ROOT/tools/bin/cdsdoc and edit cdsdoc
3. Search and find "LD_ASSUME_KERNEL=2.2.5" , it should be at some "if" structure. Looks like they use IF structure for some x86 and AMD adaptive
4. Change "2.2.5" to your KERNEL version
5. Run cdsdoc
6. Done
GOOD LUCK
cdsdoc libstdc++-libc6.1-1.so.2
Hello,
Is there a particular command that tells you which is your kernel version?
Thanks
-Roger
Added after 2 minutes:
Ignore my previous question. I Just googled the answer.
-Roger
cdsdoc starting viewer
Hello all (again),
I changed the LD_ASSUME_KERNEL in the cdsdoc file to the the value of my kernel and it still it doesn't work. I still get the message that libnsl.so.1 cannot be opened when I double-click on a particular help topic. I've been on this bug for a week now and I think I have hit a brick wall. Hence I would appreciate if someone would answer the following questions:
1. Must the ISR patches (for IC610) be installed, for cdsdoc to function properlly?
2. Do other files besides cdsdoc need to be edited (to correct the kernel version)?
3. I am using RHEL 5.1. Must it be updated ? (if so, I do not know how.., got to do more reading:( )
4. Is it importamt that RHEL be running in client, client+workstation or client+workstation+virtualization mode? (I have installed RHEL 5 client. Since I am new to linux, I wanted to start with sometning that sounded simple)
Thank you
-Roger
cdsdoc install libthread.so.1
Try to comment this part of your cdsdoc file:
# Set variable for Java to run on RedHat Linux 7.1
#if [ $PLATFORM = "lnx86" ]; then
#	if [ $ARCH = "x86_64" ]; then
#		# AMD Opteron RHEE3.0
#		LD_ASSUME_KERNEL=2.4.19
#		export LD_ASSUME_KERNEL
#	else
#		#Standard x86 systems
#		LD_ASSUME_KERNEL=2.2.5
#	fi
#fi
gl&hf
maplelmg libpthread.so.0
I tried to start cdsdoc on Fedora 8 and had the same issue: obServer was not starting. Using ldd I noticed that obServer was missing libjvm.so (java virtual machine). I added the directory <cds_install>/ic610/tools/jre1.50/lib/i386/client/ to the path for searching dynamic libraries in my /etc/ld.so.conf, then ran ldconfig.
After ldconfig, I tried to open a document in cdsdoc; it still complained about obServer, but if I manually ran obServer, it started complaining about the missing web browser.
I made a link named "netscape" to firefox, and then cdsdoc launched firefox, a blank page appeared with only one line saying "Starting..." but the document did not appear.
I suspect obServer should be started with some directory where the documents should be found.
I am still working on this... If I do further steps I'll let you know.
am
export cdsdoc
The link to firefox is needed
netscape -> firefox
Also you need to hunt down all the missing libraries it complains about and put then in any directory you like and add the path to that dir to LD_LIBRARY_PATH.
Problems about java are usually solved by renaming the jre folders that came with the program in question and making a link jre -> jre folder of the system java _and_ it needs to be sun's java not any of the alternatives.
In my experience the LD_ASSUME_KERNEL variable shouldn't even be set for things to work properly.
tscm libpthread.so.0
I have solved this problem, spend me a lot of time:
there are three reason we don't get cdsdoc working:
1: java want to set LD_ASSUME_KERNEL to current kernel version
2: obServer want LD_ASSUME_KERNEL set to null
3: https need libstdc++-libc6.1-1.so.2
since I am using ubuntu, so this solution is base on ubuntu.
1.edit $INST_DIR/mmsim610/tools/bin/cdsdoc and $INST_DIR/ic610/tools/bin/cdsdoc like this:
#LD_ASSUME_KERNEL=2.4.19
LD_ASSUME_KERNEL=2.6.27
else
fi
fi
2.edit $INST_DIR/mmsim610/tools/bin/obServer and $INST_DIR/mmsim610/tools/bin/obServer like this
LD_ASSUME_KERNEL=
3. download compat-libstdc++-296-2.96-135.i386.rpm
tar zxf compat*tgz
sudo apt-get install alien
cd usr/lib
sudo cp libstdc++-2-libc6.1-1-2.9.0.so /lib32/libstdc++-libc6.1-1.so.2
now cdsdoc works fine.
libgcc_s.so.1 and cdsdoc
st01liyp
thanks so much!
i run cadence ic610 on gentoo now!
cdsdoc ubuntu
else
fi
fi
LD_ASSUME_KERNEL=
tar zxf compat*tgz
cd usr/lib
I guess you must have a x86_64 arch
For user who uses a i386 arch,just edit the else block in both cdsdoc and obServer file like this
#LD_ASSUME_KERNEL=2.6.27
else
#LD_ASSUME_KERNEL=2.2.5
fi
fi
and then
sudo cp libstdc++-2-libc6.1-1-2.9.0.so /usr/lib/libstdc++-libc6.1-1.so.2
Thanks a lot "st01liyp", hope everyone good luck! My cdsdoc works just fine!
BTW:My OS is Ubuntu 8.10 with kernel 2.6.27-13
cdsdoc +libpthread
else
fi
fi
LD_ASSUME_KERNEL=
tar zxf compat*tgz
cd usr/lib
else
fi
fi
and then
that' cool ,you guys save my FF and IC610 ~
opteron environment variable arch
Just open a firefox/mozilla window
then,you can use cdsdoc.
looks stupid but useful,~~
centos x86_64 ld_assume_kernel
I am now installing ic5 and other tools on centos 4.7 and I have stumbled upon this problem too.
So far all I needed to do was install any package for missing libraries.
I've found that at least under centos 4.7 I have no need to comment or change any LD_ASSUME_KERNEL lines (so far at least). To solve this last issue of cdsdoc do the following:
- create a link to firefox ln -s /usr/bin/netscape /usr/bin/firefox
- go to cdsdir/tools/lib and then do
mv libgcc_s.so.1 libgcc_s.so.1_
ln -s /lib/libgcc_s.so.1 libgcc_s.so.1
(for centos it is like this, for other distros libgcc_s.so.1 may be in /usr/lib I think, create the link accordingly)
and thats all, you should have cdsdoc working well.
Thanks Rookie,
Done exactly what you've advised, and resolved the libgcc error !
but now I get a new error:
12:56pm [centos]> cdsdoc
[1] 11090
12:56pm [centos]> CDSDoc, version 2.1
Copyright © 2000-2003, Cadence Design Systems, Inc.
Starting browser ...
*** NSPlugin Viewer *** WARNING: unhandled variable 17 in NPN_GetValue()
./https: error while loading shared libraries: libstdc++-libc6.1-1.so.2: cannot open shared object file: No such file or directory
Internal error: invalid timerId
obServer: Exiting: exit status: 0
