johnnyfan
Newbie level 1
Hi all,
This is my very first post on this forum. The version type is Cadence Virtuoso 6.1.5.
I try to use virtuoso ams to simulate a sar adc circuit. Everything worked fine when I used veriloga blocks to run the simulation. But an issue came when I changed the DAC block into schematic view.
I have updated the Library List and it compiled successfully, elaborated successfully. Then it just stuck at "Failed to Simulate". And I could not find the reason from log file.
Do anyone has any idea what cause this issue? I have attached the snapshot of my log file below. Please check. Thanks a lot!
Code dot - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 module SAR_ADC_Veriloga.combine_test:schematic (up-to-date) errors: 0, warnings: 0 ncvlog: Memory Usage - 9.7M program + 19.3M data = 28.9M total ncvlog: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.1s, 38.9% cpu) Successfully compiled ('SAR_ADC_Veriloga' 'combine_test' 'schematic'). Compilation successful. ncelab(64): 08.20-s019: (c) Copyright 1995-2009 Cadence Design Systems, Inc. Elaborating the design hierarchy: ncelab: *N,SFEDPL: Deploying new SFE in analog engine. "/proj/cad/library/mosis/GF65_LPe/EDA-CAD-65N-DK012_rev3/ch65lpe_alt_DK012_OA_Rev3/6_00_01_00_LB/ch65lpe_alt/../models/YI-SM00034/1C/sm00034-1c.scs", line 39: Illegal library definition found in netlist Discipline resolution Pass... Building instance overlay tables: .................... Done Loading native compiled code: .................... Done Building instance specific data structures. Design hierarchy summary: Instances Unique Modules: 26 9 Registers: 30 10 Scalar wires: 13 - Expanded wires: 8 1 Vectored wires: 4 - Always blocks: 29 9 Initial blocks: 12 2 Cont. assignments: 11 3 Interconnect: 33 - Simulation timescale: 1ps Equivalent connect instance summary: 1: combine_test.I17 2: combine_test.I13 3: combine_test.I12 4: combine_test.I11 5: combine_test.I10 6: combine_test.I9 7: combine_test.I8 8: combine_test.I7 9: combine_test.I6 10: combine_test.I16 11: combine_test.I15 12: combine_test.I14 Writing initial simulation snapshot: SAR_ADC_Veriloga.combine_test:config Elaborating analog portion of the design hierarchy: libsyracuse: @(#)$CDS: libsyracuse version 11/15/2009 22:11 (chfclx007) $(sub-version 1115 ) ncelab: Memory Usage - 24.1M program + 756.2M data = 780.3M total ncelab: CPU Usage - 0.3s system + 1.3s user = 1.6s total (3.9s, 40.4% cpu) Successfully elaborated ("SAR_ADC_Veriloga" "combine_test" "config"). ncsim(64): 08.20-s019: (c) Copyright 1995-2009 Cadence Design Systems, Inc. Failed to simulate ("SAR_ADC_Veriloga" "combine_test" "config"). txe(64): 08.20-s019: (c) Copyright 1995-2008 Cadence Design Systems, Inc.
