I want to extract data from a GPS enabled cell phone. The data I'm interested in is the co-ordinates of the current location and the contact number of the nearest police station (if available). Then, I want to send the info. about the current location on to the phone of that police station that I'd extracted earlier. Is it possible to do so? If yes, then please help.....
1 220516 Time Stamp
2 A validity - A-ok, V-invalid
3 5133.82 current Latitude
4 N North/South
5 00042.24 current Longitude
6 W East/West
7 173.8 Speed in knots
8 231.8 True course
9 130694 Date Stamp
10 004.2 Variation
11 W East/West
12 *70 checksum
I'm having Nokia 5800. It has in-built A-GPS support. Thus, it can act as a GPS reciever.
So, can we directly get the ASCII strings from the cell phone?
Also, the other purpose of our using a cell phone is to send sms from it when triggered externally by a Microcontroller.
If you are planning to use external Microcontroller then it is much easier. What you can do is, you can find some test points for GPS and GSM modem which are built-in in your cell.
1. I hope GPS will have UART interface you can take out those pins externally and connect it with your microcontrollers serial port. Then it is easy to read ASCII $GPRMC string.
2. For GSM, you need to use AT commands to send the SMS. Similarly, you need to take out the serial port of GSM modem and connect it with your microcontroller. Refer AT+CMGS command for sms send.
Well, that info. was helpful. But, is it possible to get the $GPRMC string & also send AT commands from USB port of the cell phone, or do we have to get into the circuitry of the mobile?
