External Interrupt in Microblaze
eewonder
Newbie level 5
Newbie level 5
microblaze timer interrupt
I need a example code for External Interrupt in Microblaze. Could someone help me about this?
In a main program, how to declare and setup the external interrupt
In handler function, how to detect an external interrupt when it happen, and how to clear it?
Thanks in advance
Hi
which edk version u r using?there is difference betn interrupt handling of EDK 8.2 and 9.1...let me know.
I figure out the solution
Thanks
You must register the interrupt. I used EDK9.1 I think.
This might be of use:
void InterruptHandler(void);
int main(void)
  microblaze_register_handler((XInterruptHandler)InterruptHandler, (void*)0);
  #ifdef DEBUG
  print("* Registered Interrupt Handler *\n\r");
  #endif
  microblaze_enable_interrupts();
  // Something useful here.
  return 0;
  #ifdef DEBUG
  print("* Entering Interrupt *\r\n");
  #endif
  microblaze_disable_interrupts();
  // Do something useful here :).
  #ifdef DEBUG
  print("* Leaving Interrupt *\r\n");
  #endif
I want to start learning microblaze . can any body guide me what to read and where to get them ?
