1) why we using oscillators in microcontrollers?
2) how we can select oscillators ?
3) why we using capacitors along with oscillator with controllers?
4) how oscillators affect the controllers with respect to programs?
There is a major difference between an oscillator and a crystal.
Oscillators are typically self contained entities which when properly powered provide a stable clock source.
A typical canned oscillator:
Crystals are discrete components which under proper conditions resonate and are typically incorporated into an oscillator:
Crystals in conjunction with a pair of capacitors and other components within the microcontroller form an oscillator.
The oscillator provides a stable clock source which drives the logic within the microcontroller at a predictable and stable rate.
The rate at which a microcontroller executes instruction is based on a particular number of system clock cycles, otherwise known as instruction cycles.
The following document discusses in detail the operation of a crystal based oscillator in regards to a microcontroller:
Unfortunately, there's not an internal oscillator in pic16f877a.If you want you can use just a resistor and capacitor and tie it to the oscillator IN pin,but only use this if your application don't need a precision timing.
