Explanation for Via Filling Mask
soner86
Newbie level 5
Newbie level 5
I encountered a blue mask applied to some specific vias of a PCB.
When I search for it, I found the following example:
Do you know the aim?
"vacuum-tightness for the in-circuit test" is their explanation but I could not understand what the aim clearly is.
Here is the link: **broken link removed**
Thank you.
Could it be because, using a via as a test point has the possibility of damaging the via, breaking the barrel etc (there is a lot of pressure in a jest jig) so whatthis is doing is filling the via with a conductive masking.
This then allows the via to be treated as a testpoint.
IMO still not a good idea but if your stuck then your stuck and it may get you out of a hole.
As for the colour - its of no consequence.
Thanks Mattylad,
It is logical to strengthen a via which will be used as a test point. As far as I know, via plating method is also used for thermal purposes.
Actually the term, 'vacuum-tightness' had confused me. Thanks.
I don't think this is conductive paste.
I think in-circuit-tester uses vacuum holder, to hold PCB in place during testing.
Hi GUMY,
I think your suggestion is very good but holes of the vias do not seem to be filled. They may get rid of them at the end of the process. Thanks.
