module dram_fifo (
input fxclk_in, // 26 MHz input clock pin
output [26:0] led,
output reg led_pass,
output reg led_fail,
output wire led_calib,
// ddr3 pins
inout [15:0] ddr3_dq,
inout [1:0] ddr3_dqs_n,
inout [1:0] ddr3_dqs_p,
output [13:0] ddr3_addr,
output [2:0] ddr3_ba,
output ddr3_ras_n,
output ddr3_cas_n,
output ddr3_we_n,
output ddr3_reset_n,
output [0:0] ddr3_ck_p,
output [0:0] ddr3_ck_n,
output [0:0] ddr3_cke,
output [1:0] ddr3_dm,
output [0:0] ddr3_odt
// free memory
localparam APP_MASK_WIDTH = 16;
wire pll_fb, clk200_in, clk400_in, clk200, clk400, uiclk, fxclk;
wire mem_reset, ui_clk_sync_rst, init_calib_complete;
// memory interface
reg app_en, app_wdf_wren;
wire app_rdy, app_wdf_rdy, app_rd_data_valid;
reg [127:0] app_wdf_data;
wire [127:0] app_rd_data;
wire calib_done;
reg [27:0] app_addr = 0;
reg [2:0] app_cmd = 0;
wire app_wdf_end = 1;
wire [15:0] app_wdf_mask = 0;
wire app_rd_data_end;
wire ui_clk;
wire sys_clk_i;
reg [127:0] data_to_write = {32'hAAAAAAAA, 32'hAAAAAAAA,
32'hAAAAAAAA, 32'hAAAAAAAA};
reg [127:0] data_read_from_memory = 128'd0;
// Power-on-reset generator circuit.
// Asserts resetn for 1023 cycles, then deasserts
// `resetn` is Active low reset
reg [9:0] por_counter = 1023;
always @ (posedge fxclk_in) begin
if (por_counter) begin
por_counter <= por_counter - 1 ;
end
end
wire resetn = (por_counter == 0);
clk_wiz inst
// Clock out ports
.clk200(clk200),
.clk400(clk400),
// Status and control signals
.reset(resetn),
// Clock in ports
.clk26(fxclk_in) );
mig_7series_0 mem0 (
// Memory interface ports
.ddr3_dq(ddr3_dq),
.ddr3_dqs_n(ddr3_dqs_n),
.ddr3_dqs_p(ddr3_dqs_p),
.ddr3_addr(ddr3_addr),
.ddr3_ba(ddr3_ba),
.ddr3_ras_n(ddr3_ras_n),
.ddr3_cas_n(ddr3_cas_n),
.ddr3_we_n(ddr3_we_n),
.ddr3_reset_n(ddr3_reset_n),
.ddr3_ck_p(ddr3_ck_p[0]),
.ddr3_ck_n(ddr3_ck_n[0]),
.ddr3_cke(ddr3_cke[0]),
.ddr3_dm(ddr3_dm),
.ddr3_odt(ddr3_odt[0]),
// Application interface ports
.app_addr({app_addr} ),
.app_cmd(app_cmd),
.app_en(app_en),
.app_rdy(app_rdy),
.app_wdf_rdy(app_wdf_rdy),
.app_wdf_data(app_wdf_data),
.app_wdf_mask({ APP_MASK_WIDTH {1'b0} }),
.app_wdf_end(app_wdf_wren), // always the last word in 4:1 mode
.app_wdf_wren(app_wdf_wren),
.app_rd_data(app_rd_data),
.app_rd_data_end(app_rd_data_end),
.app_rd_data_valid(app_rd_data_valid),
.app_sr_req(1'b0),
.app_sr_active(),
.app_ref_req(1'b0),
.app_ref_ack(),
.app_zq_req(1'b0),
.app_zq_ack(),
.ui_clk(uiclk),
.ui_clk_sync_rst(ui_clk_sync_rst),
.init_calib_complete(init_calib_complete),
.sys_rst(resetn),
// clocks inputs
.sys_clk_i(clk400),
.clk_ref_i(clk200)
localparam IDLE = 3'd0;
localparam WRITE = 3'd1;
localparam WRITE_DONE = 3'd2;
localparam READ = 3'd3;
localparam READ_DONE = 3'd4;
localparam PARK = 3'd5;
reg [2:0] state = IDLE;
localparam CMD_WRITE = 3'b000;
localparam CMD_READ = 3'b001;
assign led_calib = ~calib_done;
assign led = data_read_from_memory[26:0];
always @ (posedge ui_clk) begin
if (ui_clk_sync_rst) begin
state <= IDLE;
app_en <= 0;
app_wdf_wren <= 0;
end else begin
case (state)
IDLE: begin
if (calib_done) begin
state <= WRITE;
end
end
WRITE: begin
if (app_rdy & app_wdf_rdy) begin
state <= WRITE_DONE;
app_en <= 1;
app_wdf_wren <= 1;
app_addr <= 0;
app_cmd <= CMD_WRITE;
app_wdf_data <= data_to_write;
end
end
WRITE_DONE: begin
if (app_rdy & app_en) begin
app_en <= 0;
end
if (app_wdf_rdy & app_wdf_wren) begin
app_wdf_wren <= 0;
end
if (~app_en & ~app_wdf_wren) begin
state <= READ;
end
end
READ: begin
if (app_rdy) begin
app_en <= 1;
app_addr <= 0;
app_cmd <= CMD_READ;
state <= READ_DONE;
end
end
READ_DONE: begin
app_en <= 0;
end
if (app_rd_data_valid) begin
data_read_from_memory <= app_rd_data;
state <= PARK;
end
end
PARK: begin
if (data_to_write == data_read_from_memory) begin
led_pass <= 0;
end else if (data_to_write != data_read_from_memory) begin
led_fail <= 0;
end
end
default: state <= IDLE;
endcase
end
end
endmodule
