cooldude040
Member level 2
Latchup
When PNP transistor will be on?? I think if the Vbe<0.7 then it will be on am i right? So can anyone explain this statement?
atchup may begin when Vout drops below GND due to a noise spike or an improper circuit hookup (Vout is the base of the lateral NPN Q2). If sufficient current flows through Rsub to turn on Q2 (I Rsub > 0.7 V ), this will draw current through Rwell. If the voltage drop across Rwell is high enough, Q1 will also turn on, and a self-sustaining low resistance path between the power rails is formed. If the gains are such that b1 x b2 > 1, latchup may occur. Once latchup has begun, the only way to stop it is to reduce the current below a critical level, usually by removing power from the circuit.
The link for this material is
http://www.piclist.com/images/edu/drexel/ece/www/http/ECE/ECE-E431/latch-up/latch-up.html
Please explain this..Its very important....This point is something related to Ground Bounce and Power bounce so Can anyone explain for PNP transistor?? How this is getting on? As it is a pnp transistor so to make this transistor on we need Vbe<0.7 am i right????? check out and explain me as soon as possible...........
I will be grateful to u if u can do this for me
Bye take care
Bye take care
