expecting 'endmodule', found 'else'
Abhisek hota
Newbie level 1
Newbie level 1
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
module ram_mem(din,add,rst,clk,en,rw,dout);
input [3:0]din;
input [5:0]add;
input rst,clk,en,rw;
output reg [3:0]dout;
reg [3:0]mem[0:63];
always@(clk)
begin
if(en)
    begin
        always@(posedge clk or negedge rst)
            begin
                if(rw)
                    mem[add]<=din;
                else
                    dout<=mem[add];
            end
    end
else
    begin
        always@(negedge clk or negedge rst)
            begin
                if(rw)
                    mem[add]<=din;
                else
                    dout<=mem[add];
            end
    end
end
endmodule
Unpaired begin end statements, just count it and correct according to the intended program function.
Looks like you have pasted some code unintentionally twice, alos the surrounding always @(clk) makes no sense. I guess you wanted something like below.
By the way, using proper indentation can help you to read your own text.
8
9
10
if(en)
begin
  begin
    if(rw)
      mem[add]<=din;
    else
      dout<=mem[add];
  end
end
8
9
10
if(en)
begin
  begin
    if(rw)
      mem[add]<=din;
    else
      dout<=mem[add];
  end
end
If (en) begin
always @ (posedge clk or negedge rst)
end
This isn't legal Verilog. It would only be legal if en was a static value at compile time, i.e a parameter or constant (selective compile based on a constant), but not using an input.
I think the OP doesn't know how to write the simplest behavioral description of a flip-flop:
// simplest FF
always @ (posedge clk)
  q <= d;
// simple FF with async reset
  if (!rst) q <= 0;
  else      q <= d;
Reactions: FvM
    FvM
