chandra2027
Newbie level 5
ok i m designing an antenna with MS FEED LNE technique for 3 to 5 ghz application and i want to give it a planer shape (for eg: A ,E,F,U slot) but when i m designing it i am facing given problems and i cant understand how can i solve these problems?:
1) The background does not touch the following boundaries "Perf1_INF_GND.This may prouduce an incorrect result(when solution setup define)
2) Port WavePort:The port has no terminals defined on it.(when excitation assign then wave port give this warning).
3) Port WavePort1:The number of terminals must be between 1 and 25.(and also this error fir excitation)
