ethernet interface using pic16f877
jvnbabu
Newbie level 2
bangalore, karnataka, india
i'm using a pic16f877. I've to interface with a ethernet...... i wud like to know if there is a suitable transreceiver which can be used here.... and the corresponding links where i can study them
I used both in same project :
RTL8201CL ( Realtek )
W3150A+ ( wiznet )
you would be better off going to a PIC18F97J60 Microcontroller which has an onboard integrated 10Mbps Ethernet communications peripheral
PIC18F87J60
you can then use Microchip's TCP/IP stack software
the PIC18F97J60 with the TCP/IP stack is easy to use either using TCP virtual circuits, UDP datagrams or more advanced TCP applications
if your must use a PIC16 have a look at the Lantronix XPORT serial to Ethernet modules
I have run a PIC24 UART at 921,600 bps when talking to these devices
i ve tried using dat but da availability of this pic18f is very less..... n it is costly to import..... so im searching for other options
the PIC18F97J60 with on board ethernet may be a cheaper alternative than a PIC16 with an external Ethernet device, e.g. I know the XPORT is about £20
you could go to a PIC32 with onboard ethernet but I would expect that to be even more expensive and complex
