ESR of ceramic capacitor. How to read the resistance-frequency graph?
ridgemao1983
Junior Member level 1
This graph is from murata's capacitor selection tool.
The lowest impedance is 0.003Ohm at 0.9Mhz.
The lowest resistance is 0.002Ohm at 0.2Mhz.
I think I should use the impedance-frequency graph, so the ESR of the capacitor is 0.003Ohm and the resonant frequency is 0.9Mhz.
But what is the meaning of the resistance-frequency graph? If the "resistance" means the real part of the impedance, the resistance shouldn't vary with the frequency.
Both Mutara and TDK capacitors have the graph for resistance-frequencies and impedance-frequencies, what is the meaning of this "resistance"?
Only in a over-simplified first order model. If you consider ESR as the real impedance part of a series equivalent circuit, it will be of course frequency dependend:
- because it also represents dielectric losses. By nature of the measurement, they can't be distinuished from true series resistance.
- because series resistance is frequency dependend itself, due to skin effect and proximity effect.
The capacitor will resonate with its lead inductance to give a true minimum impedance, at higher frequencies the increasing impedance of the inductance of the leads will lead to a rise in impedance, which will be inductive.
Frank
See forum post by Genomerics wrt ESR of caps
