Errors with NcSim when doing Front-end simulation with SDF annotation
zhanggd
Newbie level 5
My design has two modules: sender and receiver. So I have two top module for these two modules (sender.v and receiver.v).
Firstly, I use a top module (top.v) to contain these two modules. Just like;
/////top.v/////
module top(
// Inputs
rst,
i0, i1, i2, i3, oa,
// Outputs
o0, o1, o2, o3, ia,
checkout0, checkout1, checkout2, checkout3
sender sender(...);
receiver receiver(....);
endmodule
I use a testbench (test_top.v) of the top module to do simulation. I use Design compiler to synthesize the top module and get the gate-level netlist (top.v) and the sdf file (top.sdf). I put the system task $sdf_annotate("../data/top.sdf",r) in the testbench. Then I use the script below to do frontend simulation.
ncvlog ../data/top.v
ncvlog -sv ../test_top.v
ncelab -timescale 1ns/1ps -access +rwc worklib.test_top
ncsim -tcl test_top
Then no errors or warnings occur. So this should be a right flow.
But I need to add some behavioral level module between sender and receiver which should not be synthesized. So I need to synthesize the two modules respectively.
I get two gate-level netlists (sender.v and receiver.v) and two sdf files (sender.sdf and receiver.sdf). Then I wrote a testbench to include these two modules and put the tasks $sdf_annotate("../data/sender.sdf",s); $sdf_annotate("../data/receiver.sdf",r); in the initial module of the testbench.
Then I ran this script to simulate the whole design.
ncvlog ../data/ultra_sender.v
ncvlog ../data/ultra_receiver.v
ncsim -tcl test_top
Then, errors occur when it read the sender.sdf (I am confused of why receiver.sdf can be correctly read while the sender.sdf can not, actually I use the same dc script to synthesize these two modules with only a bit constrains. The sender module is very simple)
Errors are:
Reading SDF file from location "../data/sender.sdf"
Reading SDF file from location "../data/receiver.sdf"
ncelab: *W,SDFANS: Attempt to annotate to non-existent source port OB at scope level CheckGen_6__wrapperPE.co2.U2 <../data/sender.sdf, line 647>.
ncelab: *W,SDFAND: Attempted INTERCONNECT annotation to non-existent destination port A at scope level CheckGen_6__wrapperPE.co2.U2 <../data/sender.sdf, line 653>.
ncelab: *W,SDFAND: Attempted INTERCONNECT annotation to non-existent destination port B at scope level CheckGen_6__wrapperPE.co2.U2 <../data/sender.sdf, line 654>.
ncelab: *W,SDFAND: Attempted INTERCONNECT annotation to non-existent destination port S at scope level CheckGen_6__wrapperPE.co2.U2 <../data/sender.sdf, line 655>.
ncelab: *W,SDFAND: Attempted INTERCONNECT annotation to non-existent destination port I at scope level CheckGen_6__wrapperPE.co2.U3 <../data/sender.sdf, line 652>.
ncelab: *W,SDFCTE: Module BUFEHD of instance test_top.s.CheckGen_7__wrapperPE.co2.U4 does not match SDF celltype of INVCHD, skipping annotation <../data/sender.sdf, line 6480>.
ncelab: *W,SDFCTE: Module BUFEHD of instance test_top.s.CheckGen_7__wrapperPE.co1.U4 does not match SDF celltype of INVCHD, skipping annotation <../data/sender.sdf, line 6532>.
ncelab: *W,SDFCTE: Module BUFEHD of instance test_top.s.CheckGen_6__wrapperPE.co2.U4 does not match SDF celltype of INVCHD, skipping annotation <../data/sender.sdf, line 6893>.
ncelab: *W,SDFCTE: Module MUX2EHD of instance test_top.s.CheckGen_6__wrapperPE.co2.U3 does not match SDF celltype of INVCHD, skipping annotation <../data/sender.sdf, line 6902>.
ncelab: *W,SDFCTE: Module INVCHD of instance test_top.s.CheckGen_6__wrapperPE.co2.U2 does not match SDF celltype of MXL2CHD, skipping annotation <../data/sender.sdf, line 6911>.
ncelab: *W,SDFCTE: Module BUFEHD of instance test_top.s.CheckGen_6__wrapperPE.co1.U4 does not match SDF celltype of INVCHD, skipping annotation <../data/sender.sdf, line 6945>.
ncelab: *W,SDFCTE: Module BUFEHD of instance test_top.s.CheckGen_5__wrapperPE.co2.U4 does not match SDF celltype of INVCHD, skipping annotation <../data/sender.sdf, line 7306>.
ncelab: *W,SDFCTE: Module BUFEHD of instance test_top.s.CheckGen_5__wrapperPE.co1.U4 does not match SDF celltype of INVCHD, skipping annotation <../data/sender.sdf, line 7358>.
ncelab: *W,SDFCTE: Module BUFEHD of instance test_top.s.CheckGen_4__wrapperPE.co2.U4 does not match SDF celltype of INVCHD, skipping annotation <../data/sender.sdf, line 7719>.
ncelab: *W,SDFCTE: Module BUFEHD of instance test_top.s.CheckGen_4__wrapperPE.co1.U4 does not match SDF celltype of INVCHD, skipping annotation <../data/sender.sdf, line 7771>.
ncelab: *W,SDFCTE: Module BUFEHD of instance test_top.s.CheckGen_3__wrapperPE.co2.U4 does not match SDF celltype of INVCHD, skipping annotation <../data/sender.sdf, line 8132>.
ncelab: *W,SDFCTE: Module BUFEHD of instance test_top.s.CheckGen_3__wrapperPE.co1.U4 does not match SDF celltype of INVCHD, skipping annotation <../data/sender.sdf, line 8184>.
ncelab: *W,SDFCTE: Module BUFEHD of instance test_top.s.CheckGen_2__wrapperPE.co2.U4 does not match SDF celltype of INVCHD, skipping annotation <../data/sender.sdf, line 8545>.
ncelab: *W,SDFCTE: Module BUFEHD of instance test_top.s.CheckGen_2__wrapperPE.co1.U4 does not match SDF celltype of INVCHD, skipping annotation <../data/sender.sdf, line 8597>.
ncelab: *W,SDFCTE: Module BUFEHD of instance test_top.s.CheckGen_1__wrapperPE.co2.U4 does not match SDF celltype of INVCHD, skipping annotation <../data/sender.sdf, line 8958>.
ncelab: *W,SDFCTE: Module BUFEHD of instance test_top.s.CheckGen_1__wrapperPE.co1.U4 does not match SDF celltype of INVCHD, skipping annotation <../data/sender.sdf, line 9010>.
ncelab: *W,SDFCTE: Module BUFEHD of instance test_top.s.CheckGen_0__wrapperPE.co2.U4 does not match SDF celltype of INVCHD, skipping annotation <../data/sender.sdf, line 9371>.
ncelab: *W,SDFCTE: Module BUFEHD of instance test_top.s.CheckGen_0__wrapperPE.co1.U4 does not match SDF celltype of INVCHD, skipping annotation <../data/sender.sdf, line 9423>.
ncelab: *W,SDFCTE: Module AO222HHD of instance test_top.s.SDL_8__dc2_s2.U1 does not match SDF celltype of AO222EHD, skipping annotation <../data/sender.sdf, line 12467>.
ncelab: *W,SDFCTE: Module AO222HHD of instance test_top.s.SDL_6__dc2_s3.U1 does not match SDF celltype of AO222EHD, skipping annotation <../data/sender.sdf, line 12943>.
ncelab: *W,SDFCTE: Module AO222HHD of instance test_top.s.SDL_5__dc2_s0.U1 does not match SDF celltype of AO222EHD, skipping annotation <../data/sender.sdf, line 13419>.
ncelab: *W,SDFINC: The interconnect src test_top.s.CheckGen_7__wrapperPE.co2.U2.OB is not connected to the destination test_top.s.CheckGen_7__wrapperPE.comp.U3.C1 in instance <../data/sender.sdf, line 573>. The interconnect request will be replaced with a port annotation at the destination.
ncelab: *W,SDFINC: The interconnect src test_top.s.CheckGen_7__wrapperPE.co2.U1.OB is not connected to the destination test_top.s.CheckGen_7__wrapperPE.comp.U1.I in instance <../data/sender.sdf, line 563>. The interconnect request will be replaced with a port annotation at the destination.
ncelab: *W,SDFINC: The interconnect src test_top.s.CheckGen_7__wrapperPE.co2.U2.OB is not connected to the destination test_top.s.CheckGen_7__wrapperPE.U3.I1 in instance <../data/sender.sdf, line 530>. The interconnect request will be replaced with a port annotation at the destination.
ncelab: *W,SDFINC: The interconnect src test_top.s.CheckGen_7__wrapperPE.co2.U2.OB is not connected to the destination test_top.s.CheckGen_7__wrapperPE.U8.I1 in instance <../data/sender.sdf, line 526>. The interconnect request will be replaced with a port annotation at the destination.
ncelab: *W,SDFINC: The interconnect src test_top.s.SDL_15__dc2_s0.U1.O is not connected to the destination test_top.s.CheckGen_7__wrapperPE.co2.U2.S in instance <../data/sender.sdf, line 581>. The interconnect request will be replaced with a port annotation at the destination.
ncelab: *W,SDFINC: The interconnect src test_top.s.SDL_15__dc2_s1.U1.O is not connected to the destination test_top.s.CheckGen_7__wrapperPE.co2.U1.S in instance <../data/sender.sdf, line 584>. The interconnect request will be replaced with a port annotation at the destination.
ncelab: *W,SDFINC: The interconnect src test_top.s.CheckGen_7__wrapperPE.co2.U1.OB is not connected to the destination test_top.s.CheckGen_7__wrapperPE.U2.S in instance <../data/sender.sdf, line 534>. The interconnect request will be replaced with a port annotation at the destination.
ncelab: *W,SDFINC: The interconnect src test_top.s.CheckGen_6__wrapperPE.co2.U3.O is not connected to the destination test_top.s.CheckGen_6__wrapperPE.co2.U1.A in instance <../data/sender.sdf, line 656>. The interconnect request will be replaced with a port annotation at the destination.
ncelab: *W,SDFINC: The interconnect src test_top.s.CheckGen_5__wrapperPE.co2.U2.OB is not connected to the destination test_top.s.CheckGen_5__wrapperPE.comp.U3.C1 in instance <../data/sender.sdf, line 721>. The interconnect request will be replaced with a port annotation at the destination.
ncelab: *W,SDFINC: The interconnect src test_top.s.CheckGen_5__wrapperPE.co2.U1.OB is not connected to the destination test_top.s.CheckGen_5__wrapperPE.comp.U1.I in instance <../data/sender.sdf, line 711>. The interconnect request will be replaced with a port annotation at the destination.
ncelab: *W,SDFINC: The interconnect src test_top.s.CheckGen_5__wrapperPE.co2.U2.OB is not connected to the destination test_top.s.CheckGen_5__wrapperPE.U3.I1 in instance <../data/sender.sdf, line 678>. The interconnect request will be replaced with a port annotation at the destination.
ncelab: *W,SDFINC: The interconnect src test_top.s.CheckGen_5__wrapperPE.co2.U2.OB is not connected to the destination test_top.s.CheckGen_5__wrapperPE.U8.I1 in instance <../data/sender.sdf, line 674>. The interconnect request will be replaced with a port annotation at the destination.
ncelab: *W,SDFINC: The interconnect src test_top.s.SDL_11__dc2_s0.U1.O is not connected to the destination test_top.s.CheckGen_5__wrapperPE.co2.U2.S in instance <../data/sender.sdf, line 729>. The interconnect request will be replaced with a port annotation at the destination.
ncelab: *W,SDFINC: The interconnect src test_top.s.SDL_11__dc2_s1.U1.O is not connected to the destination test_top.s.CheckGen_5__wrapperPE.co2.U1.S in instance <../data/sender.sdf, line 732>. The interconnect request will be replaced with a port annotation at the destination.
ncelab: *W,SDFINC: The interconnect src test_top.s.CheckGen_5__wrapperPE.co2.U1.OB is not connected to the destination test_top.s.CheckGen_5__wrapperPE.U2.S in instance <../data/sender.sdf, line 682>. The interconnect request will be replaced with a port annotation at the destination.
ncelab: *W,SDFINC: The interconnect src test_top.s.CheckGen_4__wrapperPE.co2.U2.OB is not connected to the destination test_top.s.CheckGen_4__wrapperPE.comp.U3.C1 in instance <../data/sender.sdf, line 795>. The interconnect request will be replaced with a port annotation at the destination.
When I only simulate the sender module with a test_sender including $sdf_annotate("../data/sender.sdf",s). It is right. Only when I combine the two modules, errors appear.
In addition, part of the sender.sdf is (I do not add wire load in the synthesis):
(DELAYFILE
(SDFVERSION "OVI 2.1")
(DESIGN "sender")
(DATE "Sat Nov 3 11:44:50 2012")
(VENDOR "fsc0h_d_sc_tc")
(PROGRAM "Synopsys Design Compiler cmos")
(VERSION "C-2009.06-SP5-2")
(DIVIDER /)
(VOLTAGE 1.20:1.20:1.20)
(PROCESS "TCCOM")
(TEMPERATURE 25.00:25.00:25.00)
(TIMESCALE 1ns)
(CELL
(CELLTYPE "sender")
(INSTANCE)
(DELAY
(ABSOLUTE
(INTERCONNECT U51/O U86/I1 (0.000:0.000:0.000))
(INTERCONNECT oa U86/I2 (0.000:0.000:0.000))
(INTERCONNECT U86/O U85/I (0.000:0.000:0.000))
(INTERCONNECT U86/O U84/I (0.000:0.000:0.000))
(INTERCONNECT SDL_14__dc2_s3/U1/O U83/I (0.000:0.000:0.000))
(INTERCONNECT U83/O U82/I1 (0.000:0.000:0.000))
(INTERCONNECT U40/O U82/I2 (0.000:0.000:0.000))
(INTERCONNECT SDL_15__dc2_s3/U1/O U81/I (0.000:0.000:0.000))
(INTERCONNECT U81/O U80/I1 (0.000:0.000:0.000))
(INTERCONNECT U38/O U80/I2 (0.000:0.000:0.000))
(INTERCONNECT SDL_12__dc2_s3/U1/O U79/I (0.000:0.000:0.000))
(INTERCONNECT U79/O U78/I1 (0.000:0.000:0.000))
(INTERCONNECT U44/O U78/I2 (0.000:0.000:0.000))
(INTERCONNECT SDL_13__dc2_s3/U1/O U77/I (0.000:0.000:0.000))
(INTERCONNECT U77/O U76/I1 (0.000:0.000:0.000))
(INTERCONNECT U42/O U76/I2 (0.000:0.000:0.000))
(INTERCONNECT SDL_10__dc2_s3/U1/O U75/I (0.000:0.000:0.000))
(INTERCONNECT U75/O U74/I1 (0.000:0.000:0.000))
(INTERCONNECT U48/O U74/I2 (0.000:0.000:0.000))
(INTERCONNECT SDL_11__dc2_s3/U1/O U73/I (0.000:0.000:0.000))
(INTERCONNECT U73/O U72/I1 (0.000:0.000:0.000))
(INTERCONNECT U46/O U72/I2 (0.000:0.000:0.000))
(INTERCONNECT SDL_8__dc2_s3/U1/O U71/I (0.000:0.000:0.000))
(INTERCONNECT U71/O U70/I1 (0.000:0.000:0.000))
(INTERCONNECT U22/O U70/I2 (0.000:0.000:0.000))
(INTERCONNECT SDL_9__dc2_s3/U1/O U69/I (0.000:0.000:0.000))
(INTERCONNECT U69/O U68/I1 (0.000:0.000:0.000))
(INTERCONNECT U20/O U68/I2 (0.000:0.000:0.000))
(INTERCONNECT SDL_6__dc2_s3/U1/O U67/I (0.000:0.000:0.000))
(INTERCONNECT U67/O U66/I1 (0.000:0.000:0.000))
(INTERCONNECT U26/O U66/I2 (0.000:0.000:0.000))
(INTERCONNECT SDL_7__dc2_s3/U1/O U65/I (0.000:0.000:0.000))
(INTERCONNECT U65/O U64/I1 (0.000:0.000:0.000))
(INTERCONNECT U24/O U64/I2 (0.000:0.000:0.000))
(INTERCONNECT SDL_4__dc2_s3/U1/O U63/I (0.000:0.000:0.000))
(INTERCONNECT U63/O U62/I1 (0.000:0.000:0.000))
(INTERCONNECT U30/O U62/I2 (0.000:0.000:0.000))
(INTERCONNECT SDL_5__dc2_s3/U1/O U61/I (0.000:0.000:0.000))
(INTERCONNECT U61/O U60/I1 (0.000:0.000:0.000))
(INTERCONNECT U28/O U60/I2 (0.000:0.000:0.000))
(INTERCONNECT SDL_2__dc2_s3/U1/O U59/I (0.000:0.000:0.000))
(INTERCONNECT U59/O U58/I1 (0.000:0.000:0.000))
(INTERCONNECT U34/O U58/I2 (0.000:0.000:0.000))
(INTERCONNECT SDL_3__dc2_s3/U1/O U57/I (0.000:0.000:0.000))
(INTERCONNECT U57/O U56/I1 (0.000:0.000:0.000))
(INTERCONNECT U32/O U56/I2 (0.000:0.000:0.000))
(INTERCONNECT SDL_0__dc2_s3/U1/O U55/I (0.000:0.000:0.000))
(INTERCONNECT U55/O U54/I1 (0.000:0.000:0.000))
(INTERCONNECT U50/O U54/I2 (0.000:0.000:0.000))
(INTERCONNECT SDL_1__dc2_s3/U1/O U53/I (0.000:0.000:0.000))
(INTERCONNECT U53/O U52/I1 (0.000:0.000:0.000))
(INTERCONNECT U36/O U52/I2 (0.000:0.000:0.000))
(INTERCONNECT rst U51/I (0.000:0.000:0.000))
(INTERCONNECT SDL_0__dc2_s0/U1/O U50/I1 (0.000:0.000:0.000))
(INTERCONNECT SDL_0__dc2_s2/U1/O U50/I2 (0.000:0.000:0.000))
(INTERCONNECT SDL_0__dc2_s1/U1/O U50/I3 (0.000:0.000:0.000))
(INTERCONNECT SDL_10__dc2_s0/U1/O U48/I1 (0.000:0.000:0.000))
//all interconnect are (0.000:0.000:0.000)
(CELL
(CELLTYPE "NR2EHD")
(INSTANCE U86)
(DELAY
(ABSOLUTE
(IOPATH I1 O (0.519:0.519:0.519) (0.222:0.222:0.222))
(IOPATH I2 O (0.506:0.506:0.506) (0.194:0.194:0.194))
(CELL
(CELLTYPE "BUFEHD")
(INSTANCE U85)
(DELAY
(ABSOLUTE
(IOPATH I O (0.525:0.525:0.525) (0.366:0.368:0.368))
(CELL
(CELLTYPE "BUFEHD")
(INSTANCE U84)
(DELAY
(ABSOLUTE
(IOPATH I O (0.507:0.507:0.507) (0.358:0.360:0.360))
(CELL
(CELLTYPE "INVCHD")
(INSTANCE U83)
(DELAY
(ABSOLUTE
(IOPATH I O (0.049:0.053:0.053) (0.024:0.025:0.025))
(CELL
(CELLTYPE "ND2CHD")
(INSTANCE U82)
(DELAY
(ABSOLUTE
(IOPATH I1 O (0.066:0.066:0.066) (0.041:0.042:0.042))
(IOPATH I2 O (0.080:0.086:0.086) (0.039:0.039:0.039))
(CELL
(CELLTYPE "INVCHD")
(INSTANCE U81)
(DELAY
(ABSOLUTE
this was a long time ago but did you find out what it was that caused the messages like:
Did you find a way to overcome it or find out what the simulator actually does with the delays of these nets?
Regards
Giorgos
Hi, sorry to reply you so later. You can see https://www.edaboard.com/threads/159031/
Regards
Giorgos
