Error with data and its width mismatch
raghava
Member level 2
Hi all,
I am facing error with the following code.
The error line is --if(count = '0')........................error is --0 definitions of operator "=" match here
What might be the cause.
Any help is appreciated.
procedure non_maximal_sppression is
variable count: integer:=0;
begin
count := 0;
for i in 0 to 3 loop
for j in 0 to 3 loop
if(cornerness(row*IC+col) < non(i*3+j)) then
count := 1;
end if;
end loop;
end loop;
if(count = '0') then
non_max(row*IC+col) <= cornerness(row*IC+col);
else
non_max(row*IC+col) <= real(0);
end if;
end loop;
end loop;
end non_maximal_sppression;:|
You declare count as integer but in the comparison you use std_(u)logic comparison '0'. It should be just count = 0
Devas
