When I try to read in the saif file into design compiler, which is created from the vcd file generated from rtl simulation in modelsim, I am getting the following error:
Error: No switching activity has been annotated. (PWR-362)
Warning: There are 711 objects not found during annotation.
what is the possible reason for this. How to resolve this.
This usually means that the saif annotation has not been successfull. Problem may lie in the
instance name used in 'read_saif' command.
To fix this problem:
the ' -instance_name' option of the read_saif command MUST list the name of instance as in your saif file.
