Register Log in
Error when setting up Cadence IC5141 on Fedora Core6
ahmed709
Junior Member level 1
alsalam alykom
i tried to setup Cadence IC5141 tools on fedora core6 but there is an error message appeared to me after the appearance of dots and it contains :
Checking data files...
Executing control programs (pre-load) ...
sort: open failed: +3: No such file or directory
expr: syntax error
SL-8: No information available on :.
Call the Cadence Customer Response Center (CRC) at 1-800-Cadenc2
(1-800-223-3622) to get the right /usr/local/sd/install/tmp/mediaMap.lnx86 file.
so can any one help?????
thank you
alsalam alykom
VSMVDD
Banned
scotland uk
Re: Big proplem!!!!!
back up your work
completely uninstall the app
clean the registry with a cleaner tool
reboot clean again
make sure to delete any old left over directories
and reinstall
otherwise delete the offending file as its write protected or registered
something has gone wrong with the update and it cant find files at an older path location
remove and fresh install is best
:D
ahmad_abdulghany
San Jose, California, USA
Re: Big problem!!!!!
First, remove any installation files created..
Then, try to update your FC6 before installation..
Log-in as root, then open a shell:
write the following line:
yum -y -update
It will take long time (depending on your ineternet speed)
then re-install tools.
I hope it work now.
Best wishes,
Ahmad,
salem_eng1
Member level 2
Egypt
I have the same problem during the installation
I tried to update and the same problem is still happen
I want to modify this error it appear during the check of the aviliabale space on the hard disk
Are your selections correct? [y/n] y
Generating detailed installation data...
Determining available disk space
sort: open failed: +2: No such file or directory
Determining required disk space
Disk checks successful
Thank you
ahmad_abdulghany
Salem,
Please switch again to Suse 10 (refer to this post)
Although it's not the best Linux distribution for tools, but it may be the best and less problems with you as a linux users.
You and your group as well, install Suse carefully, and follow steps accurately to edit files and install Cadence..
But take care! to avoid reinstalling tools in case of Linux system fault, make a separate partion (ext3 format) with mount point: /usr/local on which you will install tools then, if any problems occured to your Linux, or even if you installed another Linux version (say RedHat, Fedora, or even higher version of Suse), what you will only do is to re-configure environment variables in either the .bashrc or .bash_profile for running the tools..
Start working immideately!
Report any problems to me..
Best Wishes,
Ahmad,
shockie
Big problem!!!!!
I don't know if IC5141 works on FC6. I met some glibc problem. don't know how to resolve it.
spweda
Full Member level 3
For the EDA purpose, do not use the updated Linux release since the EDA software was developed based on the old Lnux version. Linux 2.4 version is the best. Even if you install the 2.6 kernel Linux, you still need set the kernel as 2.4 to run Cadence ic5141.
Toggle Sidebar
