dpaul
Advanced Member level 5
I cannot figure out why VCS is throwing this error. Given below is the error message and then part of the code where error occurs.
VCS error message:
Error-[V2KGEUV] Unknown or bad value for genvar
/home/dpaul/rev28462_fpga/src/top_modules/axi_interconnect_v1_06_a/ict106_protocol_conv_bank.v, 228
Elaboration time unknown or bad value encountered for generate if-statement
condition expression.
Please make sure it is elaboration time constant.
Line 228 is:
if ((C_AXI_PROTOCOL[slot*32+:32] == P_AXILITE) || (C_AXI_PROTOCOL[slot*32+:32] == P_AXI3)) begin : gen_prot_conv
Now I give the parameter values which are SUPPOSED TO BE TAKEN during compilation:
C_NUM_SLOTS = 2
C_AXI_PROTOCOL = {1{32'h00000002}}
P_AXI3 = 32'h1;
P_AXILITE = 32'h2;
I have even manually substituted some of the parameters by their values, but the result is the same. Any hints as to how do I debug this or what is causing the error?
Note- This code snippet where the error is occuring is part of the Xilinx AXI4 Interconnect IP. I am integrating this IP in my system and so have only changed the parameters in the top-level file of the AXI interconnect.
VCS error message:
module ict106_protocol_conv_bank #
// parameter declarations come here (OVERRIDDEN by top-level parameters)
// AXI signals come here
// some wire declarations
genvar slot;
generate
for (slot=0;slot<C_NUM_SLOTS;slot=slot+1) begin : gen_protocol_slot
ict106_axi_protocol_converter #(
// some AXI parameters come here
) conv_inst (
// AXI port connections come here
// Bunch of assign statements
end
end
endgenerate
endmodule
Line 228 is:
C_NUM_SLOTS = 2
P_AXI3 = 32'h1;
P_AXILITE = 32'h2;
