Hello, I get the following error while running an Ocean script from the CIW window
*Error* times: can't handle (6.28 * nil)
*Error* load: error while loading file - "mosfets.ocn" at line 178
Cadence® Analog Distributed Processing option: Job `job024' ran and completed successfully
I can run the simulation from the ADE L window and see the waveforms also.
Can someone suggest a solution to this problem I face while running the ocean script ?
