LIBRARY ieee ;
USE ieee.std_logic_1164.all ;
USE ieee.std_logic_signed.all;
entity bit_comparator2 is
port(a, b, gt, eq, lt :in bit; agtb, aeqb, altb
ut bit);
end bit_comparator2;
architecture gate_level of bit_comparator2 is
component inv port (i1:in bit; o1
ut bit); end component;
component nand2 port(i1,i2:in bit; o1
component nand3 port(i1,i2,i3:in bit; o1
signal im1,im2,im3,im4,im5,im6,im7,im8,im9,im10:bit;
begin
--agtb output
g0 : inv port map(a,im1);
g1 : inv port map(b,im2);
g2 : nand2 port map(a,im2,im3);
g3 : nand2 port map(a,gt,im4);
g4 : nand2 port map(im2,gt,im5);
g5 : nand3 port map(im3,im4,im5,agtb);
--aeqb ouyput
g6 : nand3 port map(im1,im2,eq,im6);
g7 : nand3 port map(a,b,eq,im7);
g8 : nand2 port map(im6,im7,aeqb);
--altb output
g9 : nand2 port map(im1,b,im8);
g10: nand2 port map(im1,lt,im9);
g11: nand2 port map(b,lt,im10);
g12: nand3 port map(im8,im9,im10,altb);
end gate_level;
LIBRARY ieee ;
entity inv is
port(i1:in bit; o1
ut bit);
end inv;
architecture single_delay of inv is
begin
o1 <= not i1 ;
end single_delay;
LIBRARY ieee ;
entity nand2 is
ut bit);
end nand2;
architecture single_delay1 of nand2 is
begin
o1 <= i1 nand i2 ;
end single_delay1;
LIBRARY ieee ;
entity nand3 is
ut bit);
end nand3;
architecture single_delay2 of nand3 is
begin
o1 <= not(i1 and i2 and i3) ;
end single_delay2;
