I am doing layout with TSMC035 4M2P. I face with folowing problem:
Whenever I add the resistor 'rnwod', the LVS check tool generates the
error message: "malformed device nrdip". (please see attached file)
Do you know what is the reason and how to solve the problem?
Can this error be waived or we have to remove all error?
Re: Error "malformed device nrdip" in TSMC035 when
I have just reviewed this violation and I can give the answer to you.
LVS rule deck has option regarding resistor's connection that any resistors have no connection, malformed device errors will be generated.
Could you try to give the connection on the plus & minus pins of resistor, you can get the good results.
Merry Christmas!!
Mr. dal, thanks for your reply.
Even I connect both resistor pins to other devices, I do face with this error.
The attached file is for illustration purpose only.
In real situation, I connect all devices together and that error still exists.
Anyone has experience about this please help me.
May be a special identification layer is missing in your layout, or was missed to be extracted? Is it a salicide-blocked resistor? In this case the salicide blocking layer must be present. Just a guess!
I agree with erikl.
And I will give just a comment for you.
This malformed device error was created during netlist extraction from layout.
So you can find extraction information that is seed region and pin region of each device in the VLW window.
If this device has no any information regarding seed region and pin resgion,
layout is wrong.
BYD, did you use Pcell?
If Pcell has malformed error, please contact TSMC.
