ERROR -- Incorrect number of interface nodes for X_U1
mohd113
Junior Member level 1
I am trying to simulate a memristor with SUBCKT code (memristor component is named U1)
* Ron, Roff - Resistance in ON / OFF States
* Rinit - Resistance at T=0
* D - Width of the thin film
* uv - Migration coefficient
* p - Parameter of the WINDOW-function
* for modeling nonlinear boundary conditions
* x - W/D Ratio, W is the actual width
* of the doped area (from 0 to D)
.SUBCKT memristor Plus Minus PARAMS:
+ Ron=100 Roff=16K Rinit=11K D=10N uv=10F p=10
* DIFFERENTIAL EQUATION MODELING *
Gx 0 x value={ I(Emem)*uv*Ron/D^2*f(V(x),p)}
Cx x 0 1 IC={(Roff-Rinit)/(Roff-Ron)}
Raux x 0 1T
* RESISTIVE PORT OF THE MEMRISTOR *
Emem plus aux value={-I(Emem)*V(x)*(Roff-Ron)}
Roff aux minus {Roff}
*Flux computation*
Eflux flux 0 value={SDT(V(plus,minus))}
*Charge computation*
Echarge charge 0 value={SDT(I(Emem))}
* WINDOW FUNCTIONS
* FOR NONLINEAR DRIFT MODELING *
*window function, according to Joglekar
.func f(x,p)={1-(2*x-1)^(2*p)}
*proposed window function
;.func f(x,i,p)={1-(x-stp(-i))^(2*p)}
.ENDS memristor
my circuit code that is generated by Orcad for simulataion is
R_R1 -1 0 100 TC=0,0
V_V1 -1 0 SIN 0V 0.1V 0.56Hz 0 0 0
X_U1 -1 0 MEMRISTOR PARAMS: RON=100 ROFF=16K RINIT=11K D=10N UV=10F P=10
**** RESUMING trail1.cir ****
.END
then it give me the error
What can I do to solve this problem?
Thanks
There's apparently no syntax error. The simulation runs flawlessly in LTspice.
So do you know what is the problem. Secondly, could you tell me how you simulated it on LTSpice Thanks
I don't recognize a problem.
You can add a .tran simulation command and open the *.cir file in LTSpice. Refer to ´the help file for details.
I didn't yet check if the behavioral expressions are completely understood by LTSpice but there are at least equivalent means available.
