a_wahba
Junior Member level 1
- Joined
- Mar 13, 2012
- Messages
- 16
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Zagazig, Egypt
- Activity points
- 1,519
I have install cadence ic6.1.5 and MMSIM10 on Suse 11.4
when simulating a simple resistive circuit to check my installation
I get the following log file
Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
Version 10.1.0.204 32bit -- 14 Sep 2010
Copyright (C) 1989-2010 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, Virtuoso and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
Protected by U.S. Patents:
5,610,847; 5,790,436; 5,812,431; 5,859,785; 5,949,992; 5,987,238;
6,088,523; 6,101,323; 6,151,698; 6,181,754; 6,260,176; 6,278,964;
6,349,272; 6,374,390; 6,493,849; 6,504,885; 6,618,837; 6,636,839;
6,778,025; 6,832,358; 6,851,097; 6,928,626; 7,024,652; 7,035,782;
7,085,700; 7,143,021; 7,493,240; 7,571,401.
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
User: aya Host: linux-fnym HostID: 7F0200 PID: 25640
Memory available: 155.2875 MB physical: 3.9034 GB
CPU Type: Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz
Processor PhysicalID CoreID Frequency
0 0 0 2933.0
1 0 1 2933.0
Simulating `input.scs' on linux-fnym at 1:34:27 PM, Sat Oct 6, 2012 (process id: 25640).
Environment variable:
SPECTRE_DEFAULTS=-E
Command line:
/Tools/cadence/MMSIM/tools.lnx86/spectre/bin/32bit/spectre \
input.scs +escchars +log ../psf/spectre.out +inter=mpsc \
+mpssession=spectre0_25321_3 -format sst2 -raw ../psf \
+lqtimeout 900 -maxw 5 -maxn 5
spectre pid = 25640
Loading /Tools/cadence/MMSIM/tools.lnx86/tools.lnx86/cmi/lib/5.0/libinfineon_sh.so ...
Loading /Tools/cadence/MMSIM/tools.lnx86/tools.lnx86/cmi/lib/5.0/libphilips_sh.so ...
Loading /Tools/cadence/MMSIM/tools.lnx86/tools.lnx86/cmi/lib/5.0/libsparam_sh.so ...
Loading /Tools/cadence/MMSIM/tools.lnx86/tools.lnx86/cmi/lib/5.0/libstmodels_sh.so ...
/usr/lib/gcc/i586-suse-linux/4.5/cc1: /Tools/cadence/MMSIM/tools.lnx86/tools.lnx86/lib/libstdc++.so.6: version `GLIBCXX_3.4.14' not found (required by /usr/lib/libppl_c.so.4)
/usr/lib/gcc/i586-suse-linux/4.5/cc1: /Tools/cadence/MMSIM/tools.lnx86/tools.lnx86/lib/libstdc++.so.6: version `GLIBCXX_3.4.14' not found (required by /usr/lib/libppl.so.9)
Time for NDB Parsing: CPU = 638.902 ms, elapsed = 653.385 ms.
Time accumulated: CPU = 638.902 ms, elapsed = 653.385 ms.
Peak resident memory used = 28.1 Mbytes.
Time for Elaboration: CPU = 25.996 ms, elapsed = 28.2309 ms.
Time accumulated: CPU = 664.898 ms, elapsed = 681.783 ms.
Peak resident memory used = 33 Mbytes.
Time for EDB Visiting: CPU = 0 s, elapsed = 51.9753 us.
Time accumulated: CPU = 665.898 ms, elapsed = 682.11 ms.
Error found by spectre during initial setup.
ERROR (SPECTRE-4080): There are no components in the circuit.
Aggregate audit (1:34:28 PM, Sat Oct 6, 2012):
Time used: CPU = 667 ms, elapsed = 683 ms, util. = 97.7%.
Time spent in licensing: elapsed = 604 ms, percentage of total = 88.4%.
Peak memory used = 33 Mbytes.
spectre completes with 1 error, 0 warnings, and 0 notices.
spectre terminated prematurely due to fatal error.
all the libraries (libstdc++so.6(GLIBXX3.4.14)), libppl_c.so.4, and libppl.so.9 are installed correctly
please help me to fix this error
thanks
0 0 0 2933.0
1 0 1 2933.0
SPECTRE_DEFAULTS=-E
Command line:
spectre pid = 25640
thanks
