Error in ModelSim when I use schematic
mostafa ahmed
Member level 1
Egypt
library xilinxcorelib not found
Dear friends,
When I use Xilinx program and I use schematic and simulate this by using ModelSim, It give me this error
Error: (vsim-19) Failed to access library 'xilinxcorelib_ver' at "xilinxcorelib_ver".
# No such file or directory. (errno = ENOENT)
# ** Error: (vsim-19) Failed to access library 'unisims_ver' at "unisims_ver".
# ** Error: (vsim-3033) pp.vf(34): Instantiation of 'AND2' failed. The design unit was not found.
# Region: /pp
# Searched libraries:
# ** Error: (vsim-19) Failed to access library 'xilinxcorelib_ver' at "xilinxcorelib_ver".
# work
# Loading work.glbl
# Error loading design
# Error: Error loading design
Can any one help me please.
Thanks in advance.
Mostafa
why there is no replay
I don't know
please help me quickly
modelsim error library xilinxcorelib not found
The errors are because Modelsim cannot find the simulation libraries in the Xilinx
tools directory.
As it is asking about Verilog libraries (_ver) you need to look in the xilinx \ verilog directory
and see if the libraris are there.
Xilinx do have pre-compiled simulation models for Xilinx, or you can just go down into
the src \ XilinxCoreLib & unisims and point Modelsim's library path to these directories.
Modelsim should then compile-up any library cell it needs.
If you still have no joy, then find the Xilinx docs for schematic entry and see if there is a
section on simulating (I'm pretty sure there is, but it was a long time ago).
Hope this helps.
Tink!
