Error in compiling c++ in visual studio 2010
syedshan
Advanced Member level 1
Jeonju, South Korea
Dear all
1>------ Build started: Project: trainmaterial_step1_temp, Configuration: Debug Win32 ------
1> step1_tempcode2.cpp
1>step1_tempcode2.obj : error LNK2019: unresolved external symbol __4FM_ReceiveData referenced in function _main
1>step1_tempcode2.obj : error LNK2019: unresolved external symbol __4FM_SendData referenced in function _main
1>step1_tempcode2.obj : error LNK2019: unresolved external symbol __4FM_SelectTarget referenced in function _main
1>step1_tempcode2.obj : error LNK2019: unresolved external symbol __4FM_ResetDevice referenced in function _main
1>step1_tempcode2.obj : error LNK2019: unresolved external symbol __4FM_OpenDeviceEx referenced in function _main
1>step1_tempcode2.obj : error LNK2019: unresolved external symbol __4FM_CloseDevice referenced in function "void __cdecl exit_handler(void *,void *,struct tag_4FM_DeviceContext *)" (?exit_handler@@YAXPAX0PAUtag_4FM_DeviceContext@@@Z)
1>C:\Users\Syedshan\Desktop\VS shan\trainmaterial_step1_temp\Debug\trainmaterial_step1_temp.exe : fatal error LNK1120: 6 unresolved externals
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
I have added the relevant include files and library files paths as well and I am sure (at least by my part) that the function called is quite visible to the compiler...
I tried everything but the error does not remove. I have attached the code as well below
#include <stdio.h>		// printf()
#include <stdlib.h>               // srand(), rand()
#include <time.h>		// time()
#include <string.h>              // memcmp()
#include <4FM.h>			// 4DSP's  Application Programming Interface header
#include <malloc.h>		// _aligned_malloc/free(), this is a windows specific header
#define _MEMORY_SIZE	4096		// 4096 bytes is the maximum size we can transfer without to overflow FIFOs in the ifpga interface.
// function called to free buffers, handle to the 4DSP's device and then exit the application
void exit_handler(void *buf1, void *buf2, _4FM_DeviceContext *dev_ctx)
	// Release the instance to the hardware
	if(dev_ctx!=NULL)
		_4FM_CloseDevice(dev_ctx);
	// Free the buffers
	if(buf1!=NULL)
		_aligned_free(buf1);
	if(buf2!=NULL)
		_aligned_free(buf2);
	// Exit the application
	exit(0);
int main(int argc, char* argv[])
_4FM_error_t api_status;		// the variable receiving status of the API
	_4FM_DeviceContext dev_ctx;		// handle to the device opened
	char *dma_buffer_in;			// buffer used for our DMA transactions ( hardware to host )
	char *dma_buffer_out;			// buffer used for our DMA transactions ( host to hardware )
	char devicetype[1024];			// receive the device type ( during _4FM_OpenDEviceEx() call )
	int devicenumber;				// receive the device number ( during _4FM_OpenDEviceEx() call )
	// DMA ( Direct Memory Access ) implementation requires 4k aligned buffers in the memory.
	// we allocate both buffers.
	dma_buffer_in = (char *)_aligned_malloc(_MEMORY_SIZE, 4096);
	dma_buffer_out = (char *)_aligned_malloc(_MEMORY_SIZE, 4096);
	// Open the 4DSP hardware
	api_status = _4FM_OpenDeviceEx(&dev_ctx, devicetype, &devicenumber, OPEN_MODE_FIRST_DEVICE_FOUND);
	if(api_status!=_4FM_OK) {
		printf("No devices found in the system, exiting...\n");
		exit_handler(dma_buffer_in, dma_buffer_out, &dev_ctx);
	printf("Found device %s at index %d\n", devicetype, devicenumber);
	// Place software, firmware and hardware into a known sane state
	api_status = _4FM_ResetDevice(&dev_ctx);
		printf("Could not reset, exiting...\n");
	// We tell the firmware to route DMA transaction between the host and FPGA B, the main FPGA
	api_status = _4FM_SelectTarget(&dev_ctx, tgMainFPGA);
		printf("Could not tell the hardware to route DMA transaction to the main fpga exiting...\n");
	// Create random data, this data is sent to the firmware afterwards
	srand((unsigned int)time(0));
	for(int i = 0; i < _MEMORY_SIZE; i++)
		dma_buffer_out[i] = (char)rand();
	// Send the data to the hardware using direct memory address operations
	api_status = _4FM_SendData(&dev_ctx, dma_buffer_out, _MEMORY_SIZE);
		printf("Could not send random data to the hardware device...\n");
	// Receive the data from the hardware using direct memory address operations
	api_status = _4FM_ReceiveData(&dev_ctx, dma_buffer_in, _MEMORY_SIZE);
		printf("Could not receive random data from the hardware device...\n");
	// compare the buffer send to the hardware and the buffer received from the hardware.
	// they should be equal as the hardware looped-back the data.
	if(memcmp(dma_buffer_out, dma_buffer_in, _MEMORY_SIZE))
		printf("Error, the data echoed by the hardware does not match the data we've sent out\n");
	else
	  printf("Success, the data echoed by the hardware does match the data we've sent out\n");
	printf("The test has finished!\n");
	// Terminate properly
later while searching it has something to do with the .obj file...
How can I link the libraries in .obj files... what actually is it?
kingslayer
Member level 4
Milano, Italy
Try adding an external declaration of functions at file-scope, just before the exit_handler function, e.g.
extern <ret_type> _4FM_CloseDevice(...);
Cheers
syedshan
Jeonju, South Korea
Capture.PNGHey thanks for your reply brother
I tried including extern as well with the function declaration. But it is not working...
It just gives the messages...unresolved external symbol....
What to do.... can bear this any more... :(
Well I have also uploaded the image... I have added all the libraries all right but why this things happening.
Bests,
Shan
kingslayer
Member level 4
Milano, Italy
Hi there,
Now the errors are less than in the previous post, isn't it? This means that the extern tip I suggested you could work if you extern all the other functions for which you got the error (although this is not the best way to do it :wink:). So, how are those functions declared in the header file?
Cheers
