freemanantony
Member level 4
- Joined
- May 19, 2010
- Messages
- 70
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Chennai, India
- Activity points
- 2,005
hello
i trying to interface eeprom with 8051 with i2c. i am getting syntax error near sda= and scl=.can anyone help me
#include<reg51.h>
#include<stdlib.h>
#define SDA P3^5
#define SCL P3^4
unsigned char tempdata;
void delay()
unsigned char i;
for(i=0x00;i<0xFF;i++);
void longdelay(void)
int h,s;
for(s=0;s<0x50;s++)
for(h=0;h<0xff;h++);
void scl_high()
hg:
SCL=1;
if(SCL!=1)
goto hg;
void start()
SDA=1;
scl_high();
SDA=0;
delay();
SCL=0;
void stop()
SDA=0;
scl_high();
SDA=1;
void write (unsigned char data1)
unsigned char i;
for(i=0;i<8;i++)
SCL=0;
if (data1 & 0x80)
SDA = 1;
else
SDA = 0;
SCL = 1;
data1 = data1 << 1;
delay();
SCL = 0;
do {
SDA = 1;
} while(SDA==1);
void read()
unsigned char j;
unsigned char tp;
unsigned char dat;
SDA = 1;
for(j=0;j<8;j++)
scl_high();
tp = SDA;
if (tp==1)
dat = (tempdata | 0x01);
else
dat = (tempdata & 0xFE);
tempdata = dat<<1;
SCL = 0;
delay();
delay();
delay();
SDA = 1;
scl_high();
SCL = 0;
void eeprom_write(unsigned char address, unsigned char dat)
start();
write(0x00);
write(address);
write(dat);
stop();
void eeprom_read(unsigned char address)
start();
write(0x00);
write(address);
stop();
start();
write(0x01);
read();
stop();
void sent (unsigned char dat)
while(TI==0);
SBUF = dat;
void send_data()
unsigned char R;
unsigned char J;
R = tempdata & 0xF0;
R = R >> 4;
R = R + 0x30;
sent (R);
J = tempdata & 0x0F;
J = J + 0X30;
sent (J);
void main()
unsigned char address = 0x00;
unsigned char dat = 0x3E;
EA=0;
longdelay();
longdelay();
longdelay();
longdelay();
TMOD = 0X20;
SCON = 0X50;
TH1 = 0XFD;
eeprom_write(address, dat);
eeprom_read(address);
while(1)
send_data();
#include<reg51.h>
#include<stdlib.h>
#define SDA P3^5
#define SCL P3^4
void delay()
unsigned char i;
int h,s;
for(s=0;s<0x50;s++)
void scl_high()
hg:
SCL=1;
if(SCL!=1)
goto hg;
void start()
SDA=1;
scl_high();
SDA=0;
delay();
SCL=0;
void stop()
SDA=0;
scl_high();
SDA=1;
unsigned char i;
for(i=0;i<8;i++)
SCL=0;
if (data1 & 0x80)
SDA = 1;
else
SDA = 0;
SCL = 1;
data1 = data1 << 1;
delay();
SCL = 0;
do {
SDA = 1;
} while(SDA==1);
void read()
unsigned char j;
unsigned char tp;
unsigned char dat;
SDA = 1;
for(j=0;j<8;j++)
scl_high();
tp = SDA;
if (tp==1)
else
tempdata = dat<<1;
SCL = 0;
delay();
delay();
delay();
SDA = 1;
scl_high();
SCL = 0;
start();
write(0x00);
write(address);
write(dat);
stop();
start();
write(0x00);
write(address);
stop();
start();
write(0x01);
read();
stop();
while(TI==0);
SBUF = dat;
void send_data()
unsigned char R;
unsigned char J;
R = R >> 4;
R = R + 0x30;
sent (R);
J = J + 0X30;
sent (J);
void main()
EA=0;
longdelay();
longdelay();
longdelay();
longdelay();
TMOD = 0X20;
SCON = 0X50;
TH1 = 0XFD;
while(1)
send_data();
