would somebody please help me to correct the error that i face. please see the attached picture.
I am using Quartus II Version 8.0, schematic design. when i compile the design I face the Error: Can't find name for bus. I am new on Quaetus. please help.
You have probably confused it by connecting together named busses.
disconnect the ff ouptuts and the ram input, and instead use named association, ie. name the ff outputs Data[31..24] etc, and the ram input Data[31..0]
you havent disconnected them, you have left them connected.
Connection is done by physical connection or named association, not both like you have.
On a side note - using a logic generated clock is not generally a good idea, especially if the data bus is running at the same frequency as the counter. You should use clock enables instead.
Oh, and it also looks like you've used a bus signal when you meant it to be a single bit (Q[0])
